Results 1 to 9 of 9
- 08-17-2011, 10:03 PM
Thread Author #1
- 08-18-2011, 03:20 PM
Thread Author #2
- 08-18-2011, 04:06 PM #3
Re: Battery help
wiping bstats in term emulator or cwm will help, if you do it properly. By that I mean: (and sorry, no offense, if you know all this already! )
1. Charge handset to 100%
2. Turn handset off and continue to charge to 100%
3. Re-power the handset on and charge again to 100% (which it might already be at when it reboots)
4. Wipe bstats in tu or cwm.
This is recommended every time you make a system change, such as changing kernel or ROM. I liked to do it every time i flashed anything that made a major change, such as kernel, rom or deep theme.
However, it will take up to a week before your battery gets accustom to your new setup. The battery likes consistency. If you change things (rom, kernel, theme) frequently than don't ever expect outstanding battery life.
I am on stock ED05 and am having the best battery life to date since owning my fascinate. 18+ hours some days on a single charge.
Good Luck!I am a product of my failures.
It's not the law, just a suggestion..
"Let's Flash Together" Bigjobber69. - 08-18-2011, 05:09 PM
Thread Author #4
Re: Battery help
Yeah im running ukb 2 pbj-50 and I take it off the charge after charging both on and off and it drops almost immediately to 95%..I think im on ed04..I went ahead n wiped stats earlier and the battery went back to 95% within 30 minutes..but ill just let it get to 5% and then fully charge n do that for a while n see hiw it goes..I can barley get like 3-4 hours on a charge with wifi only on cause that's all I use with the phone its not my everyday phone but may b if I can get this battery under control
- 08-18-2011, 09:11 PM #5
Re: Battery help
I always had good luck with comavolt (kernel). You might try flashing that. I also recommend the ED05 modem, and which you should be able to Odin as a stand alone.
"Let's Flash Together" Bigjobber69. - 08-18-2011, 10:12 PM
Thread Author #6
- 08-19-2011, 08:09 AM #7
- 08-19-2011, 02:08 PM #8
Re: Battery help
Comavolt Kernel (read thread for install instructions)
ED05 Radio (Bottom of Post #4)
http://forums.androidcentral.com/ver...8-19-11-a.html
Good luckI am a product of my failures.
"Let's Flash Together" Bigjobber69. - 08-24-2011, 05:52 PM
Thread Author #9
Reply
