Results 1 to 5 of 5
- 09-26-2011, 09:33 PM
Thread Author #1
TSM Pool Party LED Flashlight
Hey, I've recently flashed TSM pool party 1.3, and its great.
However, I cant seem to get the LED Flashlight working.
It works when i take a picture, but when i use such apps
or torch(which was added in 1.3) the LED flashlight
wont just work. Any clue how to fix it? - 09-26-2011, 10:52 PM #2
- 09-27-2011, 01:02 AM #3
It's amazing how much you miss that LED once you don't have it.
Have you searched the ROMs thread to see if it is a common problem? It's always good to include your info with such questions: how did you install, what did you install etc.
SCH-I500 Tap Tap TaparooVZW GNex CM10.1 - 10-01-2011, 12:29 PM #4
Re: TSM Pool Party LED Flashlight
I just loaded up Pool Party v1.4 on my Fassy last night and torch worked just fine to turn the LED light into a flashlight. Pool Party can be found here:
ETA - Also, Sbrissen ported the CM ring lockscreen over to Pool Party. If you haven't seen this lockscreen, you have to check it out it is amazing.
Shouldn't we treat this world like the Garden of Eden and avoid the apple at all costs?
Sometimes you go to the circus...........Sometimes the circus comes to you.
Instructions on how to flash ROMs, Kernels, Patches, and Mods through clockworkmod recovery, CWM: DroidXcon's CWM Thread
If you add me on Google+, please list your AC username as a nickname so I know who you are. - 12-23-2011, 02:57 AM #5
Reply
