Results 1 to 19 of 19
Like Tree1Likes
  • 5 Post By gunnermike53
  • 1 Post By gunnermike53
    gunnermike53's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Gummy, AOKP
    Default Accurate Battery Mod for JT's ICS Build 6 30 Jan 2012
    This is just an accurate battery mod for JT's ICS build 6. Flash in cwm.
    Download Acc Battery Mod
  2. #2
    big_limits's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    TSM RES/TKSGB BE
    Default Re: Accurate Battery Mod for JT's ICS v3
    Where would one find said build
  3. #3
    bigjobber69's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    rootzwiki
  4. #4
    ckrenek23's Avatar
    Posts
    Global Posts
    83 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cyanogen Mod 7
    Default
    Awesome, love me some ics with accurate battery
    Sent from my GT-P7510 using Tapatalk
  5. #5
    tekhinator's Avatar
    Posts
    Global Posts
    109 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    OMFGB 1.3.1/Glitch
    Sweet dude thanks!
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Gummy, AOKP
    Default Re: Accurate Battery Mod for JT's ICS 1209
    op updated
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Gummy, AOKP
    updated for Build 1
  8. #8
    sushiguy732's Avatar
    Posts
    Global Posts
    1,514 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Gummy ICS
    Default Re: Accurate Battery Mod for JT's ICS Build 1 14 Dec 2011
    ok... so i updated my phone with this and THEN read it is for ICS and I am running SC. If you are wondering what happens when you do a bone head move like this I'll tell you. Not only do you not get an accurate battery.... you get no battery or any other notifications for that matter. I no longer have access to my notification bar.
    I tried to re-flash his accurate battery mod for SC but so far no luck. Trying it again now. Maybe the second time is a charm.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Gummy, AOKP
    updated for build 2
  10. #10
    KevinPhelps11's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by sushiguy732 View Post
    In this case, I would flash you ROM again.
  11. Thread Author  Thread Author    #11
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Gummy, AOKP
    Default Re: Accurate Battery Mod for JT's ICS Build 4 29 Jan 2012
    updated for build 4
    bigjobber69 likes this.
  12. Thread Author  Thread Author    #12
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Gummy, AOKP
    Default Re: Accurate Battery Mod for JT's ICS Build 6 30 Jan 2012
    op updated for build 6
  13. #13
    PensHockey's Avatar
    Posts
    Global Posts
    968 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So will this only work on build 6 or will it work up to build 6? I am using this as a test phone and am on build 5 and see no reason to update to build 6 for just a MMS fix. But will do it if its really that much better.
    Thanks
  14. #14
    scndmdw's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ICS
    Can you post a screenshot of the battery mod itself?
  15. Thread Author  Thread Author    #15
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Gummy, AOKP
    Quote Originally Posted by scndmdw View Post
    its the ics battery with numbers on it.
  16. Thread Author  Thread Author    #16
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Gummy, AOKP
    Quote Originally Posted by BigCrisco39 View Post
    Thanks
    um...idk. flash it and see, whats the worst that could happen
  17. #17
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    kabooooooooom. Mike im still waiting on that photo! LOL made my day!
  18. #18
    Marylander1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Can anyone post a link to JT build 6 rom, Thanks
  19. #19
    scndmdw's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ICS
    Quote Originally Posted by Marylander1 View Post
    Goo-inside.me Downloads - Downloading teamhacksung_fascinatemtd-ota-eng.BUILD6.1.zip
