- 11-30-2011, 09:09 PM
Thread Author #1
Thanked by 5: - 11-30-2011, 10:46 PM #2
- 12-01-2011, 08:06 AM #3
- 12-01-2011, 09:08 PM #4
- 12-01-2011, 10:18 PM #5
Re: Accurate Battery Mod for JT's ICS v3
Sweet dude thanks!
I am that dude that wishes Salma Hayek was my wife. - 12-10-2011, 04:12 PM
Thread Author #6
Re: Accurate Battery Mod for JT's ICS 1209
op updated
- 12-14-2011, 07:16 PM
Thread Author #7
updated for Build 1
- 12-16-2011, 10:32 PM #8
Re: Accurate Battery Mod for JT's ICS Build 1 14 Dec 2011
ok... so i updated my phone with this and THEN read it is for ICS and I am running SC. If you are wondering what happens when you do a bone head move like this I'll tell you. Not only do you not get an accurate battery.... you get no battery or any other notifications for that matter. I no longer have access to my notification bar.
I tried to re-flash his accurate battery mod for SC but so far no luck. Trying it again now. Maybe the second time is a charm.עם ישראל חי - 12-20-2011, 02:22 PM
Thread Author #9
updated for build 2
- 12-31-2011, 05:52 AM #10
- 01-07-2012, 12:37 PM
Thread Author #11
Re: Accurate Battery Mod for JT's ICS Build 4 29 Jan 2012
updated for build 4
Thanked by: - 01-30-2012, 05:49 AM
Thread Author #12
Re: Accurate Battery Mod for JT's ICS Build 6 30 Jan 2012
op updated for build 6
- 01-30-2012, 09:55 PM #13
So will this only work on build 6 or will it work up to build 6? I am using this as a test phone and am on build 5 and see no reason to update to build 6 for just a MMS fix. But will do it if its really that much better.
Thanks - 01-31-2012, 10:52 PM #14
- 02-01-2012, 04:21 AM
Thread Author #15
Thanked by: - 02-01-2012, 04:22 AM
Thread Author #16
- 02-03-2012, 04:39 PM #17
- 02-05-2012, 09:47 AM #18
- 02-06-2012, 07:51 PM #19
Reply
