Currently using SC 2.9.2. Way better than the stock kernel, but I'd like to get more out of my phone, so I downloaded Clockwork by recommendation from a friend, and downloaded what appeared to be a stable ROM called StupidFast 1.54.
Download went fine, and then I started the install, and before the reboot, asked me if i wanted to Clear the Delvik Cache, Clear my memory cache, and back up my current ROM, to which I said yes to all three.
Then it rebooted my phone to that red menu, and i went to "Install from sd card" and then went to clockworks directory where the SF1.54 zip was.
I hit install, but it says syntax error in update script.
Anyone have any idea how to fix this problem?
