Results 1 to 13 of 13
    Angry Please help!! No data or voice after ROM flash
    OK so i installed a EH03 GB rom to my Fascinate, i did the set up, and authenticated my phone and it said it was successful. But i cant make calls, connect to 3G or anything like that, i cant even call verizon. I can only connect to wifi. I did a hard reset, a soft rest, tried a diffrent rom, but the same problem keeps happening. Someone please help. I beg for any help, this is very important...please.......
  2. Thread Author  Thread Author    #2
    Default Re: Please help!! Going crazy
    Please! Anybody!
  3. #3
    imokurnot's Avatar
    Posts
    Carrier
    JT's VGB
    Did you do a nandroid back up? If you did try restoring to your previous rom. I would try flashing a different radio too.
    Quote Originally Posted by imokurnot View Post
    Excuse my ignorance (which is why i am facing this problem), but what is a nandroid back up? And what do you mean try a new radio?
  5. #5
    sushiguy732's Avatar
    Posts
    Global Posts
    1,514 Global Posts
    Carrier
    Gummy ICS
    I'd call Verizon from your land line and have them activate the phone.
    Quote Originally Posted by sushiguy732 View Post
    They said they couldent find the problem.
    Default Re: Please help!! No data or voice after ROM flash
    Is this really such a unusual, weird problem? I really need my phone.
  8. #8
    uofatree's Avatar
    Posts
    Carrier
    ED01 Comm Romv1.1
  9. #9
    Quote Originally Posted by aconrad12 View Post
    did you try dialing *228, option1? Then the same thing, option 2.
  10. Thread Author  Thread Author    #10
    Quote Originally Posted by lpt2569 View Post
    Does not work, just keeps dialing, tech support said it shouldent take that long
  11. Thread Author  Thread Author    #11
    Quote Originally Posted by uofatree View Post
    Why would you post a guide that has outdated links and information?
    PLEASE PLEASE PLEASE SOMEONE HELP ME
  12. #12
    Not trying to be an a$$ here, just trying to help...is your data connection actually turned on? Toggle the data switch on and off and on again. Do a battery pull and try again. If you get no data after all this, not sure what else to suggest. I think you said you used ODIN to load the stock GB ROM, correct? Try it again, and make sure you follow the steps in this guide exactly as they are stated. Go to section 5 to get you back on stock GB, a fresh install.
    [GUIDE] Installing a Rom/CWM recovery/Root or going back to Stock - xda-developers
  13. #13
    Default
    Any chance you clicked on phone in Odin instead of Pda!
    Sent from my SCH-I500 using Tapatalk
