Results 1 to 22 of 22
Like Tree1Likes
  • 1 Post By DroidXcon
    Default Odin fails, Heimdall problems, fascinate bricked?
    let me give you a quick rundown...
    i'm trying to get my old fascinate back to stock. i recently got the newest galaxy nexus, so i don't need the fascinate anymore, but was thinking about selling it or giving it away, but wanted to go back to stock first. i was running AOKP milestone 6 (i think it was m6, anyways)
    first, i tried going back to stock using EH03 and atlas pit via odin, which i've done quite a few times in the past in between roms
    this time Odin failed, though. i tried again, and it just went through super fast and i kept getting succeeded 0 / failed 0. i tried a bajillion times and this happens everytime.
    so, then i tried Heimdall. but i can't even get the drivers installed. when i go to zadig, in download mode, the only things listed are my webcam and wimax - samsung composite (or anything samsung) is not listed. i've tried uninstalling and reinstalling the samsung drivers. nothing.
    i'm using the stock usb and have tried all 3 ports on my laptop
    the phone just boots to the samsung logo and stays there indefinitely. can't get it to boot into recovery, either.
    help?
  2. #2
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default Re: Odin fails, Heimdall problems, fascinate bricked?
    Quote Originally Posted by Drake King View Post
    help?
    Do you have another computer in the house?
    From my Galaxy Note 2 via Tapatalk
    If i've made life easier buy me a Macchiato
    yeah, i can try it on a desktop. will take me a bit but i'll let ya know what happens..
  4. #4
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Yeah laptop ports are usually unreliable
    alright, tried odin on the desktop, but the ID:COM box never even turns yellow...
  6. #6
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Did you install the drivers
    the samsung drivers? yup. i downloaded the schi500 drivers and was generally following the steps posted here
    now that i noticed the box never turning yellow, that must be what was happening on my laptop, too. not sure how i missed it.
    what else can i do the phone isn't being recognized?
  8. #8
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Are you sure you are in download mode
    yeah, i have the yellow android triangle "downloading.... do not turn off target!!!!" screen
  10. #10
    Paul627g's Avatar
    Posts
    Global Posts
    13,777 Global Posts
    ROM
    Milestone 1/Lean Kernel
    Tried using a different USB cable? I know you already mentioned different ports.
  11. #11
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Unplug remove battery. Plug usb into a different port in the back of the computer. With the battery still out plug the phone on and hold down till it goes into download mode. See if it connects
    Paul627g likes this.
  12. Thread Author  Thread Author    #12
    yeah, i actually tried a new cable this last time. i was using the stock cable from the fascinate, but just tried the cable that came with my nexus, too. same thing. uninstalling the samsung drivers now and reinstalling ones directly from samsung. worth a shot.
  13. #13
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Quote Originally Posted by Paul627g View Post
    This also
  14. Thread Author  Thread Author    #14
    ok. i tried with the nexus cable, newly installed samsung drivers, and a usb port in the back. same thing. i get the downloading screen on the phone, but windows registers it as an unknown device and says it didn't install properly
  15. #15
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    I don't know what to say keep trying ports and cords.
  16. Thread Author  Thread Author    #16
    alright. i'll keep trying... thanks.
  17. #17
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Try the battery out trick
  18. Thread Author  Thread Author    #18
    what do you mean? doesn't the battery have to be out to put it in download mode anyway?
    Quote Originally Posted by DroidXcon View Post
  19. #19
    Paul627g's Avatar
    Posts
    Global Posts
    13,777 Global Posts
    ROM
    No the battery normally doesn't have to be out to enter Download Mode.
    The trick that DroidXcon is referring to is..
    • Disconnect the device from computer
    • Remove the battery and leave it out
    • Plug into the computer via USB cable
    • Now enter Download Mode with the appropriate button configuration
    • Open Odin and see if the device is now recognized.
    • If device is recognized then proceed forward flashing the tar files.
    • When complete if all goes well disconnect, pop the battery back in and boot up.
  20. Thread Author  Thread Author    #20
    ok, for some reason i'd always been under the impression that the battery needed to be out for download mode, so i've always done it with the battery out. this morning, i tried the wall charger trick (getting it into dl mode via the wall charger, then popping in the battery and plugging it into the computer) - still not recognized.
    this one might actually be dead. sigh.
    thanks for all the help, you two.
  21. #21
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    I doubt it's dead. How much were you planning to sell it for?
  22. #22
    You can't kill the Fascinate. Perhaps only if sulfuric acid is involved. If you're in download mode, you can recover. I know that's not specifically helpful...but...don't give up!!!
    Sent from my SCH-I500 using Android Central Forums
  1. Droid Charge bricked? ODIN fails every time..
    By Baba Yaga in forum Droid Charge Rooting, ROMs, and Hacks
    Last Post: 03-16-2013, 08:48 AM
  2. telus fascinate bricked
    By telkane in forum Telus Fascinate
    Last Post: 04-04-2012, 09:22 AM
  3. Problem with Bricked Optimus s
    By adolfo.diaz07 in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 10-08-2011, 10:55 AM
  4. Odin Fails, screen stuck, and no cwm
    By androidfascinate in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 04-03-2011, 02:53 PM
  5. usb problems fascinate
    By mudbutt13 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 01-27-2011, 05:16 PM
