1. chuban7's Avatar
    I get all the way untill you have to reboot and when i hit reboot nothing happens so then i try to manual boot and do the update and i get and error can someone please help me?
    09-25-2010 05:20 PM
  2. chuban7's Avatar
    bump
    09-25-2010 06:29 PM
  3. namebrandon's Avatar
    Explain what you're doing. We have no idea what your problem is until we know what exactly you're trying to do, and have done already.
    When you say stuff like
    i get and error
    no one has any idea what that means.
    09-25-2010 06:34 PM
  4. chuban7's Avatar
    Im sorry for not making myself clear this is what i meant
    I am trying to do the clockworkmod everything goes good until the part where i have to reboot , when i click it in rom manager nothing happens.
    09-25-2010 06:39 PM
  5. namebrandon's Avatar
    And you have rooted your device, right? You have Superuser.apk installed, etc..?
    09-25-2010 07:19 PM
  6. chuban7's Avatar
    yes
    09-25-2010 08:13 PM
  7. namebrandon's Avatar
    And what happens if you just go into recovery manually, and choose 'apply update.zip' ?
    09-25-2010 08:45 PM
  8. PJnc284's Avatar
    Which guide are you using? I just used Clockworkmod installation how to - xda-developers and everything went smoothly.
    09-25-2010 08:56 PM
  9. chuban7's Avatar
    I get an error saying there is no update.zip on the sd card
    09-26-2010 08:33 AM
  10. namebrandon's Avatar
    Put this on your sd card.. Not in any directory, right on the root of the SD card. Then try again.
    09-26-2010 09:40 AM
  11. chuban7's Avatar
    thanks, and can you help me with one more thing please now on my phone i keep getting this error that says " Sorry! The process android.process has stopped unexpectedly. please try again" and then the only option is force close and it keeps popping up and it is really annoying.
    09-26-2010 12:04 PM
  12. Back2iPhone#AC's Avatar
    Yes I'm having a similar issue:
    I rooted the phone successfully and have the superuser.apk
    Downloaded CM7 but it aborts and doesn't recognize file, however I downloaded a Deodexed zip file and it updated successfully (in choose zip file).
    GB Apps loaded successfully
    When I choose recovery flash file...doesn't accept and aborts.
    Is it possible to find a step by step guide to this? I'm a newbie so if you guys could be as 'Laymen" as possible it would be a HUGE help also. In advance...Thank You.
    06-08-2011 05:14 PM
  13. Landshark's Avatar
    Everything you need to know about ClockworkMod recovery you can find out in this thread:
    http://forum.androidcentral.com/veri...-captures.html
    Which version of CWM do you have? That may be the problem with not being able to flash CWM7.
    06-08-2011 05:43 PM
  14. JOrtenzi's Avatar
    What is the latest CWM 3.x that is available? I'm pretty sure I have it, just wondering. Thanks
    06-08-2011 07:27 PM
  15. bigjobber69's Avatar
    THIS IS 3.X
    Thread is here http://forum.xda-developers.com/show....php?t=1046905
    JOrtenzi likes this.
    06-08-2011 07:36 PM
  16. JOrtenzi's Avatar
    thats what i have.... thanks!
    06-08-2011 08:08 PM
  17. Landshark's Avatar
    Don't forget about the recoveries you get from flashing nemesis2all's and imnuts' latest kernels. Nemesis2all's is red and imnuts' is yellow. I believe both are labeled CWM 3.2.x
    06-08-2011 08:28 PM
  18. johnsma22's Avatar
    So that means if you have CWM 3-30 ALL and then flash one of those kernels you will now have CWM 3.2.x and if you want 3-30 ALL back you will have to reflash it in Oden? I've read about some issues with the various versions of CWM 3, so is it ok to continue to use CWM 3-30 ALL with Edify scripts?
    I flashed DL09 modem in Oden and then used CWM 3-30 ALL to flash the patch to ED03 radio (which is Edify script I believe) and it seemed to work fine. Which version do you recommend Landshark?
    06-08-2011 08:47 PM
  19. bigjobber69's Avatar
    wehh they singled you out sharky! but I will answer with my preference being 3.x considering everything coming out now is edify so makes no sense to be stuck in the past.
    06-08-2011 09:01 PM
  20. johnsma22's Avatar
    In the Com Rom 2.0 thread at XDA, and here, that it is recommended that CWM 3.x be used, but that CWM 2.x (3-30 ALL to be specific) has been successfully used. I used 3-30 ALL to flash the ED03 modem patch, which is Edify. It appears as though 3-30 ALL can flash both, but is it recommended?
    06-08-2011 09:26 PM
  21. bigjobber69's Avatar
    It most def can flash both...2.5.x can flash both and 3.x can only flash edify. I am never going to be flashing anything non edify ever again so that is why I am just never going back. Yes it is recommend because it is edify and so you should be using a straight edify CWM. Also that way you have the best chance for success.
    johnsma22 likes this.
    06-08-2011 09:51 PM
  22. Final13's Avatar
    do what big jobber says...i tried the other way and ran into problems. everything in the future will be edify so no reason to use the other really. and those are what are being developed and used by everyone.
    06-09-2011 09:59 AM
  23. lextori's Avatar
    I'm having a similar issue, rooted using the adb method I've seen posted just about everywhere. Have superuser but when I go to flash I click on the button that says reboot, and my phone just drops back into rommanager program
    I'll try the fix posted.
    Thanks for all the awesome guides here.
    06-09-2011 07:17 PM
