Since I installed voodoo lagfix I have been randomly getting the "battery is not connected" error. I have always been able to resolve this with a simple battery pull. Today I was out for a while and got home to get the 15% battery warning. I tried multiple times charge my battery but kept getting the "Battery is not connected" error and I could not get it to quit doing it no matter how many times I did a battery pull (I even let it sit for 20 minutes and still nothing). My solution was to remove voodoo by adding the disable_lagfix to the voodoo directory so I could get back to normal where the issue no longer happens. Well after adding the file I rebooted the phone with the charger plugged in and I got a female voice saying making system changes but my phone went to the battery charge icon and the icon was flashing a yellow warning triangle that has a battery with a line thru it on the screen. After an hour of nothing happening I braved to pull out the cable the phone immediately shut off I was able to reboot but the phone again said applying system changes and came back after 2 minutes to what looked like a stock TW screen. The battery showed no juice and was acting like no battery is installed. The batery then died. It will not charge if the phone is turned off I get the same image. If I reboot into recovery (power volup and voldown button) it will come into the samsung recovery and will charge the battery (it was the only way the phone would boot and after 30 mins it has some juice so I assume if i left it for a few hours it would charge there, I learned by choosing to reboot system and unplugging cable, it is back to stock TW kinda but if I plug in the USB charge it says no battery connected) HELP!
