03-23-2011 10:20 AM
34 12
tools
  1. mbuxx's Avatar
    I load odin, plug in phone, yellow box shows up. I click pda and find the .tar file and this is what i get..
    <ID:0/005> Added!!
    <ID:0/005> Odin v.3 engine (ID:5)..
    <ID:0/005> File analysis..
    <ID:0/005> SetupConnection..
    it just gets stuck at setup connection forever...
    Can anyone help?
    EDIT: also, i have a samsung fascinate with telus not with verizon... i dont know if that matters... i am a noob, but am rather good with computers!
    thanks
    11-20-2010 01:53 PM
  2. shaundizzle's Avatar
    You don't use Odin to flash clockwork recovery.
    Odin's for a fresh reset to take away clockwork and root
    Sent from my SPH-D700 using Tapatalk
    11-20-2010 01:57 PM
  3. mbuxx's Avatar
    What could I use then? I was following the instructioms by namesbrandon I believe...
    Any other suggestions would be great thanks!
    11-20-2010 02:06 PM
  4. Kevin Gossett's Avatar
    Actually, Odin is the only way to flash CWM...
    11-20-2010 02:08 PM
  5. mbuxx's Avatar
    Thanks kevin this is what I was understanding also...do you have any ideas to help me out?...also is there a way to back up so I can restore if anything goes wrong.
    11-20-2010 02:15 PM
  6. Kevin Gossett's Avatar
    I'm not sure why it's hanging like that. You can make a backup once clockwork finishes, but that doesn't really help you
    11-20-2010 02:19 PM
  7. mbuxx's Avatar
    hmm is this the only way to install clockwork? all i wanna do is install jt's super clean rom and debloat my phone..any words of wisdom? lol
    11-20-2010 02:21 PM
  8. Kevin Gossett's Avatar
    The only thing I can think is you having a different carrier. Perhaps there is a different CWM .tar you need
    11-20-2010 02:29 PM
  9. mbuxx's Avatar
    okay thanks man
    11-20-2010 02:42 PM
  10. Groundhound's Avatar
    When I first attempted to use Odin to install CWM it failed. The failure was corrected for me by taking my unpowered USB hub out and connecting the phone directly to the USB port on my computer.
    11-20-2010 03:07 PM
  11. xliderider's Avatar
    I used Z4 root to root and installed rom manager from the Market, then flashed CWM. However, the Fascinate will only boot into stock recovery.
    11-20-2010 03:13 PM
  12. Cory Streater's Avatar
    OP - you have the drivers installed, correct?
    11-20-2010 03:18 PM
  13. Kevin Gossett's Avatar
    That's because rom manager doesn't actually flash cwm. You have to do that using odin
    11-20-2010 03:26 PM
  14. 6spdtls's Avatar
    *This method only works on verizon fascinate.....not other variants(also doesn't work on mac or linux users)
    1. Make sure you have Samsung drivers installed on your pc
    2. Download odin from here to your pc
    http://dl.dropbox.com/u/458252/Odin%...in3%20v1.3.exe
    3. Download clockwork package to your pc
    http://dl.dropbox.com/u/458252/CWMrecovery.tar
    *create a folder and put those two files together on pc
    4. go to setting-> application-> development-> USB debugging
    5. on your phone
    Turn phone off-> pull the battery out completely-> plug usb to your phone
    -> press volume down until you see a triangle screen comes up
    6. on your pc
    open odin(make sure it shows yellow bar on the port; this means your phone has detected)-> click PDA and select CWMrecovery.tar-> click start
    * your phone will reboot upon completion.
    7. Using clockwork, back up your files immediately.
    download rom manager-> select flash clockwork mod-> click on fascinate-> when scanning has done, click backup current ROM
    *your phone will reboot and start backing up your file. Do not turn it off....your phone will reboot upon completion.
    Ytaay and vwinn like this.
    11-26-2010 04:37 AM
  15. vwinn's Avatar
    Trying to flash JT as well. Your odin link doesn't seem to be working. Can you repost a new host link?
    11-26-2010 12:48 PM
  16. 6spdtls's Avatar
    right click to save target. it should work
    11-26-2010 12:50 PM
  17. vwinn's Avatar
    Ok, got it. Now that it's all in order COM Port Mapping is yellow and when I click PDA, select CWM Recovery I get an Invalid Image Type error. Any suggestions?
    11-26-2010 01:00 PM
  18. 6spdtls's Avatar
    "invalid image type" is nothing to worry about as long as odin says "passed". Tell me where you're at right now.
    11-26-2010 02:09 PM
  19. vwinn's Avatar
    When I click start after ignoring Invalid Image Type it says "Check Image Files". The message says "Download start..." How long should this process take?
    11-26-2010 02:17 PM
  20. 6spdtls's Avatar
    It took me around 5minutes. do not disconnect until complete....or you'll brick your phone.
    11-26-2010 02:23 PM
  21. vwinn's Avatar
    I don't remember Odin ever saying "Passed" so I'm not sure if the process is even running. If I had to start over how would I do so (say if nothing changes after 10 minutes)?
    11-26-2010 02:26 PM
  22. 6spdtls's Avatar
    Did you change your USB setting to debug mode before you started? what is your screen saying right now? if odin doesn't say passed than, you might have to restart everything.
    11-26-2010 02:34 PM
  23. vwinn's Avatar
    Yes, debugging is enabled. My screen has a yellow triangle with "Downloading..." and under that "Do not turn of Target!!!". But that's what it looked like before I tried to flash CWM via Odin so I don't think anything's happening. I think my problem is I used Rom Manager to attempt to flash CWM as that's how I did it on my Droid.
    11-26-2010 02:38 PM
  24. 6spdtls's Avatar
    May I ask you which carrier you are using?
    11-26-2010 08:08 PM
  25. vwinn's Avatar
    Verizon
    11-27-2010 10:35 AM
34 12
