Hey folks,
I have been waiting to update so that I could release a super clean froyo version for you.
Finally, something stable. I kipped 2.7 altogether, as it was an unlucky number. So I present you with 2.8. This has been thoroughly tested and should be just fine.
Changes since 2.7/2.6:
-- Malware protection file included.
--Moved back to amend script due to flashing issues for non voodoo users, and conversion issues for voodoo users.
--Latest Maps.
--Scwitched to GizmoDroid's mms app modification. His works better than mine.
--Updated to sbrissen's latest framework, modifying the carrier edit a bit (thanks andmer for instrructions).
--Added old eb01 debinged browser, as is more stable.
--Notification shade now has a slight transparency to it, credit nitsuj17 and ludeboy.
--eb16 kernel with fake hotspot monitoring module included.
--Wifi scan interval set to 2 minutes, in an attempt to save battery. YMMV on this one. I've heard from both ends of the spectrum during testing.
--Removed LG widgets to save battery life.
--Added aosp gallery back due to suggestion from beta tester, thanks calebv2.
Many thanks to all the brave beta testers, some who had to Odin a few times until I got it right I'll be recruting more as time goes on.
Nonvoodoo
http://www.mediafire.com/?ijc3c4g622xo121
Voodoo
http://www.mediafire.com/?clgg09e91dkbqhs
It has been brought to my attention that eb16 kernels are not converting voodoo for some.
As an alternative, Ia m supplying links to these.
http://www.mediafire.com/?dq935gb0r8qc7t8
Non voodoo
Voodoo
http://www.mediafire.com/?9e2acpe0i7ba7fh
Thanks to jt1134, eb16 kernels (included in 2.8+):
eb16_nonvoodoo.zip --Nonvoodoo eb16 kernel w/ dummy tether module
eb16_voodoo.zip --Voodoo eb16 kernel w/ dummy tether module
Note 2.5 and 2.6 users!!!
If you are having issues with browser force closing on downloads, please flash this debinged browser:
http://forum.androidcentral.com/ver...g-roms-hacks/59528-eb01-debinged-browser.html
Changes since 2.5:
Removed junk files I accidently left in.
Added widgetpicker, per request.
[App] AppWidgetPicker - xda-developers
Added bstats and fxpms scripts (wipe battery stats and fix permissions).
Restored newer swype version. (oops!)
Added latest gmail app (2.3.4.1)
Added latest gmaps (5.1)
Removed carrier edits I missed (on lockscreen) when porting over sbrissen's work.
DRM has been removed as well as divx app, seeing how it relies on it. It can be added in as a patch (listed on this page).
Modifications to status and quick panel, courtesy of Ludeboy.
Nonvoodoo
super_frankenclean_2_6nv.zip
Voodoo
super_frankenclean_2_6v.zip
Mirrors
http://adbdev.com/danknub/SF_EB15.66_SFC_v2.6_voodoo.zip
http://adbdev.com/danknub/SF_EB15.66_SFC_v2.6_nonvoodoo.zip
2.5 changelog (Its big)
Merged portions of EB16 into EB01 superclean.
EB16 and superclean now share 614 (out of 857 total superclean files) of the same files. The list is too large to really show. So the rom is ~75% EB16, and the rest EB01, either stock files, or modded by me/others.
Modified sbrissen's current phone, lock, and time mods into current superclean framework. This includes aosp lock answer, am/pm/clock on-off via settings (clock off requires reboot), and better removal of full battery notification.
Go to settings, time and date to make these changes.
Added xoom boot animation, modified by mastamoon to better fit our resolution.
Modified my dialer to be a bit more elegant, now that Samsung partially fixed their typos (I fixed the rest).
Fixed the ringtone corruption on some ringtones (I think).
I SUGGEST YOU DO A DALVIK-CACHE WIPE, AT THE VERY LEAST!
Nonvoodoo
super_frankenclean_2_5nv_REL.zip
Voodoo
super_frankenclean_2_5v_REL.zip
Changes since 2.3:
Added back in the transitions I left out.
Stock browser should for now download virtually any filetype and not give unsupported message.
Car cradle now properly launches music player.
Clean quickpanel by benbowden.
Battery full popup disable by sbrissen, modified by me to include other superclean mods already in place.
Nonvoodoo now contains bootanimation support. Sorry for the delay. I am lazy
Voodoo
super_clean_2_4v.zip
Nonvoodoo
super_clean_2_4nv.zip
Mirrors
http://adbdev.com/danknub/EB01_SC_2.4_nonvoodoo.zip
http://adbdev.com/danknub/EB01_SC_2.4_voodoo.zip
Patches (load via clockwork 2.5.x):
Clock package (includes infoalarm)
http://www.mediafire.com/?hd6sl8yko13n2nj
Touchwiz video player (eb16)
http://www.mediafire.com/?s7la74ig31373ia
DRM Package (eb01)
http://www.mediafire.com/?0hu1ic8b9u0sow2
Samsung MMS (stock, eb01)
http://www.mediafire.com/?4q3jk5vcdd29hjf
Touchwiz Launcher and widgets (eb01)
http://www.mediafire.com/?hza7hpk5r88keip
TW Live walls (eb01)
http://www.mediafire.com/?9y8idfnf5lgd0he
TW Music Player (eb01)
http://www.mediafire.com/?02bpclsfkxko3ef
2.2.1 Launcher, modded for SF
http://www.mediafire.com/?svt5mgwmnf55wz4
Nuance (eb01)
http://www.mediafire.com/?f1i7b3xzz3y311u
Thinkfree Office (eb16)
http://www.mediafire.com/?sgursw4s81qmz10
--Latest Maps.
Nonvoodoo
Voodoo
Non voodoo
Voodoo
Changes since 2.5:
Nonvoodoo
Voodoo
Mirrors
Nonvoodoo
Voodoo
Changes since 2.3:
Voodoo
Nonvoodoo
Mirrors
DRM Package (eb01)
Nuance (eb01)
