Not sure if this was ever mentioned... i did catch up to about page 25 of the DL30 thread and skimmed through the rest and i read all of the new superclean thread and I don't think anyone had this problem so can someone help me out?
Long story short, I went back to stock DL09 and followed the directions and have DL30 up and running. But both of my recoveries give me this when i try to wipe anything "E:can't mount /dev/block/stl11 (no such file or directory)"
i've tried to flash the ROM and it goes through the installation process but then it hangs on the reboot... i let it sit for about 30 mins, but the very first time i upgraded it didnt take this long... i went through this process more than a handful of times going from stock DL09 and building up... dunno wut i'm doing wrong. The first time i upgraded, I was on voodoo. So i disabled voodoo, let it reboot, turned it off, went back into red recovery and checked that voodoo was disabled, then i went and flashed Adryn's test 2 NV kernel. Once i was there i proceeded with the DL30 upgrade, then the DL30 ROM and it was fine that first time... but basically i tried some other things that ended up bricking my phone so i went back to square 1 and now i'm having this problem... going to stock and back up doesn't seem to resolve this... i know i'm missing something, someone point me the right way
**EDIT**
I'm an idiot... but incase other noobs out there get confused... what I was doing was trying to flash via old CW i guess... i went into rom manager, rebooted to recovery, it was green. Then i did apply update.zip which took me to the New? green recovery where i was able to do what i needed to do without getting errors. All i know is that they look exactly the same but when i go into it by applying update.zip, i'm able to do my wipes
**EDIT**
