I've installed ROM Mgr and CWM Recovery. I go to ROM Mgr, and select flash then Samsung Fascinate then I reboot into recovery and whatever else I try to do from there i.e. nandroid, install from sd card, I keep getting the following message. Please help.
Waiting for SD Card to Mount (#s) [# being the count down 20 - 1]
E:Can't mount /dev/block/mmcblk0p1 (or /dev/block/mmcblk0)
(Device or resource busy)
Timed out waiting for SD card... continuing anyways.ROM Manager Version 2.5.0.7
Preparing to install ROM...
Can't mount /sdcard
Can't mount /sdcard
