Alright, I will try to spell out what we did to fix this. It was a HUGE pain in the butt. This was all trial and error, so YMMV.
First, grab my DI01 All in One. You need an all inclusive package.
http://adrynalyne.us/files/kernels/DI01package3.tar.md5
You will need odin3 v 1.30. Gonna assume you have it, considering the mess you are in.
You also need Heimdall.
Heimdall – Glass Echidna There is a readme in the windows version zip if you get stuck. Drivers must be installed for it as well.
You also need a copy of the samsung galaxy s usb drivers, because Heimdall will remove them when you use it.
[Drivers] MS Windows x86 and x64 USB Drivers for Samsung Galaxy S - xda-developers
You will also need a PIT file from me:
http://dl.dropbox.com/u/2056318/atlas_v2.2.pit
Steps:
1. Install Heimdall and drivers.
2. Put phone in download mode and plug it in to usb cable.
3. Unzip the Odin file. 7zip can do this, but will give an EOF error. Ignore the error.
4. Choose each section in Heimdall and add the appropriate file, including PIT. Check repartition. Primary boot loader is boot.bin and secondary boot loader is sbl.bin.
5. Start. It should finish and will likely be in a reboot loop with a crap ton of failed errors on wiping data.
6. Reinstall Samsung USB drivers for Odin. This may require a PC reboot.
7. Put phone back in download Mode and start Odin, making sure its detected.
8. Load the entire Odin package, not extracted into the pda section of Odin. Include the PIT file. CHECK repartition.
9. Run the process.
If all goes well, you should be back to stock, crappy Eclair 2.1.
