ls5012
Active member
Although I still can't get my phone rooted, ( I have searched these forums and every other forum I could find on the internet & I'm on my last nerve!!!! I did find this method for having the phone recognized by the mac. Hope this helps!
After you plug in the phone and these messages come across the status bar, swipe down on the screen and select "USB Connected" "Select to copy files to/from your computer" Then select "Mount" when the blue USB connected message pops up. Wait a few minutes until you get the "Disk you inserted was not readable" error, select "Ignore". At this point, just to be sure, open "Disk Utility" on your Mac, you should see an entry for "Samsung SCH -I500. Select it and then hit "Info". Look at the Disk Identifier, it should say disk1 or some other number. If it is disk1 just copy "gpt show /dev/disk1" without quotes and paste it in Terminal. If it is disk2 or another number just change the 1 to whatever number yours happens to be. When you have that copied in Terminal, look back at your phone and "Turn off USB Storage" select "Turn off" on the blue message that pops up, wait a few seconds and the "USB connected" "select to copy files" message comes back on your phone "select it and mount again. Then bring up your Terminal and hit enter to run the command. You should get something like this,
start size index contents
0 1 MBR
1 128
129 30904191 1 MBR part 12
0 1 MBR
1 128
