Results 1 to 22 of 22
- 03-09-2011, 05:04 PM
Thread Author #1
- 03-09-2011, 05:27 PM #2
- 03-09-2011, 05:31 PM
Thread Author #3
The only thing you want to watch for is that you don't wipe.
If you wipe, you lose your ringtone index. Easily fixed by removing the file or reflashing a rom though. - 03-09-2011, 06:50 PM
Thread Author #4
- 03-09-2011, 07:24 PM #5
You're really on the ball lately. When's SC 3.0 coming? j/k
- 03-09-2011, 07:53 PM #6
Sorry Adrynalyne, got to bug you for a question about these. Do we need to use both of these or just the new scripts one you posted? And for everyone's sake since the second one is script we would run it in terminal emulator, correct?
Shouldn't we treat this world like the Garden of Eden and avoid the apple at all costs?
Sometimes you go to the circus...........Sometimes the circus comes to you.
Instructions on how to flash ROMs, Kernels, Patches, and Mods through clockworkmod recovery, CWM: DroidXcon's CWM Thread
If you add me on Google+, please list your AC username as a nickname so I know who you are. - 03-09-2011, 08:19 PM
Thread Author #7
Yeah, scripts enable/disable, then reboot you. They stick through a wipe, too.
You only need one. The scripts are more versatile. Run via terminal emulator or adb shell. - 03-09-2011, 08:42 PM #8Shouldn't we treat this world like the Garden of Eden and avoid the apple at all costs?
If you add me on Google+, please list your AC username as a nickname so I know who you are. - 03-09-2011, 08:52 PM #9
thanks a lot Adrynalyne! this was really annoying me too and seems to take a really long time on froyo
- 03-09-2011, 09:09 PM #10
OK, so downloaded the script zip... Now what?
- 03-09-2011, 09:54 PM #11
Flash it through cwm, then open up terminal emulator, next to the $ type su, hit the enter key, wait for super user permission, then a # will appear and next to that type fast_media, hit the enter key. Done. I still haven't figured out adb, so I don't know if it is the same exact method for adb.
If you add me on Google+, please list your AC username as a nickname so I know who you are.Thanked by: - 03-10-2011, 02:01 AM #12
- 03-10-2011, 02:07 AM #13Shouldn't we treat this world like the Garden of Eden and avoid the apple at all costs?
If you add me on Google+, please list your AC username as a nickname so I know who you are. - 03-17-2011, 05:32 PM #14עם ישראל חי
- 03-17-2011, 05:46 PM #15
Where do I copy it to or how can I change my path?
עם ישראל חי - 03-17-2011, 06:29 PM #16
Will the SD card still get scanned everytime you reboot?
Thanks - 03-17-2011, 06:29 PM #17
If you don't understand ADB best to just flash through CWM Red as Landshark stated.
Put the .zip anywhere on your SD card. Boot to Recovery and when you get to the option for apply .zip from SDCard you will see all your folders. If it is in a folder go there if it is on the root of your SDCard use the vol up and down keys to scroll to it. Power key to select it. - 03-18-2011, 07:26 AM #18
עם ישראל חי - 03-18-2011, 07:32 AM #19עם ישראל חי
- 03-18-2011, 12:12 PM #20
- 03-18-2011, 02:22 PM #21Shouldn't we treat this world like the Garden of Eden and avoid the apple at all costs?
If you add me on Google+, please list your AC username as a nickname so I know who you are. - 04-25-2011, 05:10 PM #22
I have placed the media_scanner_fast.zip file on the root of my sd card, but when I flash into recovery mode (3-finger method) and choose that zip file, I'm getting a "E:can't open /sdcard/media_scanner_fast.zip(bad)" message. I've erased and re-downloaded the file a second time and tried it again only to get the same result. I love the idea of a truncated media scanner process so I'd love some advice.
Reply
