Page 4 of 9 FirstFirst 1234567 ... LastLast
Results 76 to 100 of 223
Like Tree4Likes
  1. Thread Author  Thread Author    #76
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock for now
    Default
    Quote Originally Posted by Dr.Brain View Post
    And I'll also need to extract the DI01 file before flashing via Odin, right?
    no the DI01 is packaged differently just leave it as is
  2. #77
    Dr.Brain's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thanks, DXC. I don't know how you do it but I really appreciate the assist.
  3. #78
    jenden's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default I tried this method and it did work
    This is what I got Let me know what I did wrong.
    C:\Users\Text>cd C:\FascinateRoot_v02
    C:\FascinateRoot_v02>adb devices
    * daemon not running. starting it now *
    * daemon started successfully *
    List of devices attached
    I500******** device
    C:\FascinateRoot_v02>adb push rage.bin /data/local/tmp/rage.bin
    42 KB/s (5392 bytes in 0.125s)
    C:\FascinateRoot_v02>adb shell
    $ cd /data/local/tmp
    cd /data/local/tmp
    $ chmod 0755 rage.bin
    chmod 0755 rage.bin
    $ ./rage.bin
    ./rage.bin[*] CVE-2010-EASY Android local root exploit (C) 2010 by 743C
    [*] checking NPROC limit ...
    [+] RLIMIT_NPROC={2655, 2655}[*] Searching for adb ...
    [+] Found adb as PID 2368[*] Spawning children. Dont type anything and wait for reset![*][*] If you like what we are doing you can send us PayPal money to[*] 7-4-3-C@web.de so we can compensate time, effort and HW costs.[*] If you are a company and feel like you profit from our work,[*] we also accept donations > 1000 USD![*][*] adb connection will be reset. restart adb server on desktop and re-login.
    I500******** device
    $ exit
    exit
    C:\FascinateRoot_v02>adb push su /sdcard/su
    333 KB/s (26264 bytes in 0.077s)
    $ exit
    exit
    264 KB/s (26264 bytes in 0.097s)
    C:\FascinateRoot_v02>adb push busybox /sdcard/busybox
    3222 KB/s (1867568 bytes in 0.566s)
    $ mount -t rfs -o remount,rw /dev/block/stl9 /system
    mount: Operation not permitted
    $ cd /system/xbin
    cd /system/xbin
    $ cat /sdcard/su > ./su
    cannot create ./su: read-only file system
    $ cat /sdcard/busybox > ./busybox
    cannot create ./busybox: read-only file system
    $ chmod 4755 su
    chmod 4755 su
    Unable to chmod su: No such file or directory
    $ chmod 4755 busybox
    chmod 4755 busybox
    Unable to chmod busybox: No such file or directory
    $ exit
    exit
    C:\FascinateRoot_v02>adb install Superuser.apk
    1400 KB/s (196521 bytes in 0.137s)
    pkg: /data/local/tmp/Superuser.apk
    Success
    ^C
    Quote Originally Posted by DroidXcon View Post
    What builds will this work on: All builds
    What Downloads will i need:
    One click zip file
    FascinateRoot_v02
    Directions: (Assuming you followed preparations from Post #1)
    With your phone in debugging mode set to stay awake
    1.Extract downloaded FascinateRoot_v02.zip file directly to your C:\ Drive
    so that it looks like this C:\FascinateRoot_v02
    2. Now go to your start button on your menu bar,in the run field or search field depending on your version of windows, type CMD and hit enter. The command box will present itself. From here on out just copy and paste the commands i will provide below. To paste in the command box you must right click on the mouse and select paste. Do not paste BOLD text below those are just for info.
    Commands are as follows:
    adb devices
    It will state
    "List of devices attached
    I500******* device"
    If you dont see this you are not connected
    adb shell
    cd /data/local/tmp
    chmod 0755 rage.bin
    This step is important. After you type the next command there will be a pause and you will have to wait until you are kicked out of adb shell. It is important you do not touch your phone or type anything in the command window. If you do don't worry, nothing bad will happen you will most likely have to pull your battery and try to run the command again. If your phone doesn't lock up you can probably unplug it and plug it back in and start back at "adb shell"
    ./rage.bin
    After several seconds the $ prompt will come back
    After another 20 seconds or so you will be kicked back to the C:\FascinateRoot_v02 prompt.
    adb devices
    If your device is still connected proceed,if not give it a min or to and type adb devices again. if the phone is locked up after a couple mins battery pull and start over.
    adb shell
    You should now be at a # prompt
    This mean you have achieved temporary root on the device.
    exit
    You should now be at the C:\rootfiles prompt again
    Type the following commands:
    adb shell
    cd /system/xbin
    chmod 4755 su
    chmod 4755 busybox
    exit
    You should be back at the C:\FascinateRoot_v02 prompt
    It will now install the Superuser.apk this may take some time while it installs when it is over it will say:
    Success-after you see Success hit Ctrl-C Then reset your device
    3. You have now achieved Root, congrats. If this didnt work for you well then time for a different approach.
    Here is a screen shot of what i did, you will see some mistakes i made... and at the end it says failure but i had already manually installed the Superuser.apk so thats the reason for that. this is just to give you an Idea of what you are getting yourself involved with.
    GOOD LUCK!!!!
    Trouble Shooting
    During process it can not push file because it says file not found
    A file in the FascinateRoot_v02 folder is missing or corrupted. Download FascinateRoot_v02.zip file again. and restart the process.
    adb push: Permission Denied
    SD card is mounted to your, if the sdcard is mounted there is no way for the adb to push files from your computer to your phone and on to the sdcard.. please drop down notification bar and turn off usb storage Close out and start again
    Prompt tells you that you do not have permissions
    The process failed to grant you temporary root access. Close out and begin again.
    Error Device not found
    If this happens after continuing after first reboot, this means that the phone was not properly connected before continuing. After reboot unplug the phone, plug it back in, disable media sync, mount then unmount SD card then continue.
    After installing Superuser.apk States Install failed already exists
    Chances are at some point the apk was downloaded from previous attempts to root your device. Just ignore proceed to reboot device. Download Titanium backup, open it and see if it asks you to allow or deny Superuser access. if these options come up means you are rooted. If not try the rooting process over
    Additional Conditions to check
    1. Check to make sure you installed the Samsung Drivers
    2. Make sure your phone is connected using the original cable that came with the phone
    3. Verify that debugging is enabled.
    4. Try to run it again
    5. If you are receiving errors then your phones drivers were not installed
    6. If you are having a different please post here so we can help you.
  4. Thread Author  Thread Author    #79
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock for now
    Default
    Quote Originally Posted by jenden View Post
    I500******** device
    cd /data/local/tmp
    chmod 0755 rage.bin
    $ ./rage.bin
    I500******** device
    $ exit
    exit
    this part went wrong
    adb shell
    exit
    pull the battery and try again from the top
  5. #80
    newbie4ever's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    cyanogenmod7
    Default
    Does anyone know if there's a way to use bluetooth microphone for speech to text, some kind of voodoo app or patch?
    Sent from my finger to my phone to this post using Tapatalk
  6. #81
    mhawk71's Avatar
    Posts
    Global Posts
    5 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    i just got a fascinate and am new to all this switched from a blackberrry. i downloaded the 2.2 update i was gonna root with the 1 click but i dont have the stay awake option under development and ive been reading alot of the info but now ive read so much im confused lol
  7. #82
    pikanate's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP M5/LeanMinimalistic
    Default
    Quote Originally Posted by mhawk71 View Post
    Follow post 5 in the thread. It works with Froyo.
    mhawk71 likes this.
  8. #83
    mhawk71's Avatar
    Posts
    Global Posts
    5 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    the first file listed in post 5 am i supposed to leavbe it as a zip file
  9. #84
    FearTheGhost13's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Leave it as a zip file and put it on your sdcard, it will be flashed within cwm which does the work for you.
    mhawk71 likes this.
  10. #85
    Chadwicky's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    YOU ROCK. I'm glad you included the screenshot because I was worried considering I received the failure regarding the Superuser app -- this is because I had previously rooted before updated to 2.2 OTA, which removed my root.
  11. #86
    Surbus's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    when I try to do this it seems like its working but I get this at the end
    ** Successfully exploited, installing permanent root files and deleting temp fil
    es
    /data/local/tmp/com.sh: cannot create /system/xbin/su: read-only file system
    /data/local/tmp/com.sh: cannot create /system/xbin/busybox: read-only file syste
    m
    /data/local/tmp/com.sh: cannot create /system/app/Superuser.apk: read-only file
    system
    Unable to chmod /system/xbin/su: Read-only file system
    Unable to chmod /system/xbin/busybox: Read-only file system
    * Restarting your phone now.
    Press any key to continue . . .
  12. #87
    pikanate's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Default
    Quote Originally Posted by Surbus View Post
    es
    m
    system
    just follow post 5 to root if your already on froyo.
  13. #88
    Kalnel's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by jessie02 View Post
    have looked at all the related threads and still cant find an answer..... Gone all the way back to D101 and still get the error, wiped cache, etc..... using the EZ root method. Any ideas? Thanks
    I'm having the same problem. I'm coming from the stock ED03.
    (I've had some problems with Force Close errors on the other de-bloated versions of stock Froyo, so I'd like to root ED03, rather than flashing a new package.)
  14. #89
    gorillaboze's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Ok. I followed the instruction on page 1 to:
    (1) root my phone
    (2) downloaded Titanium backup and root explorer
    (3) rename bloatware using root explorer
    Now what? do i keep it rooted or do I need to un-root it? Do I need to do anything else or will my phone function like it did before.
    Thanks for the excellent instructions and the help!
    -Chad
  15. #90
    deraildup's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I'm a novice. However, I had my fascinate rooted then upgraded to the droid os 2.1.1, then the root didnt work although the su was showing it was there. I have recently upgraded to the 2.2.1 osc buld # SCH-I500-ED01 I would like to have my root back. but I have no clue where to begin. Also the su is still showing in my aps. Can you point me in the right direction?
    Thanks
  16. #91
    Landshark's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Infinity & Pool Party
    Default
    Quote Originally Posted by gorillaboze View Post
    (1) root my phone
    -Chad
    Keep it rooted, it will function like before but also likely better & faster since you will not have the bloat
    Sent from the shark tank using Tapatalk
    gorillaboze likes this.
  17. #92
    Landshark's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Default
    Quote Originally Posted by deraildup View Post
    Thanks
    Follow the steps in post #5 of this thread
  18. #93
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thanks Landshark.
    I have read a lot about different ROMS and clockwork, do I need to worry about these? I really have no idea what they are.
  19. #94
    applepie32's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default MEMBER
    Nice!
  20. #95
    frogray66's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I think I'm doing everything quickly but this doesn't seem to be working. I am getting an error message about a "chmod" file that can't be located. Any idea what I'm doing wrong?
  21. #96
    Landshark's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Default
    Quote Originally Posted by frogray66 View Post
    If you are following the steps in post #3, those won't work on Froyo. Why make things more difficult, keep it simple - follow the steps in post #5, easy peasy quick and easy.
  22. #97
    Landshark's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Default
    Thanks Landshark.
    Read this to get you started on understanding some of this:
    http://forum.androidcentral.com/veri...3-17-11-a.html
    Then read this:
    http://forum.androidcentral.com/veri...4-28-11-a.html
    Then read this to learn about clockwork:
    http://forum.androidcentral.com/veri...-captures.html
    This will give you a lot of good info to answer your questions. As you read the first few posts in each thread and you have questions, post the questions in that thread to get the best answers.
  23. #98
    deraildup's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    on this link
    Multiupload.com - upload your files to multiple file hosting sites!
    which of the downloads should i use?
    Thanks for your patience I really am a novice at best..
  24. #99
    pikanate's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Default
    on this link
    That is the old CWM.
    The new CWM is found here
    [RECOVERY][ODIN][ZIP][4.22.11]Voodoo CWM 3.x UPDATED 5.8.11 - xda-developers
    You can either download it so you can flash it as a zip in CWM or download it where you flash it through ODIN.
  25. #100
    sburris8402's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    love the information provided here already have it working wonderfully on my phone thanks and keep up the good work
