10-26-2013 04:34 AM
1,056 ... 23456 ...
tools
  1. jjcasillas15's Avatar
    does anyone know if va green works with 2.9.2. i had it on 2.9.1 and really loved it.
    Actually flashed that this morning. Works good. Havent noticed any problems with it so far.
    03-24-2011 05:12 PM
  2. putney1477's Avatar
    What if I flash a theme and don't like it? How can I get my old theme back? I'm running EB01 SC 2.9.1.
    03-24-2011 05:38 PM
  3. JOrtenzi's Avatar
    before flashing a new theme, ALWAYS do a nandriod back-up through CWM. That way if something goes wrong, or you don't like the new theme, you can always just restore the old theme
    putney1477 likes this.
    03-24-2011 05:41 PM
  4. cwd500's Avatar
    on the va green thread on xda there is a zip for icon docks and wallpapers. it says to unzip and use as you please. what do you do with it once it is unziped?
    03-24-2011 05:41 PM
  5. JOrtenzi's Avatar
    i would think unzip the icons onto your SD card and if you want to use those images for your icons, then you can...
    where is this thread? can you post a link?
    03-24-2011 05:57 PM
  6. Brettdacosta's Avatar
    03-24-2011 05:58 PM
  7. Brettdacosta's Avatar
    As he said - unzip and use the images as you please, but as of earlier this week, the file wasn't leading anywhere. It lead to an empty MacOS folder. He said he was having some issue with it, so check it out, and if it doesn't work - maybe send him a reminder. Good luck.
    03-24-2011 06:00 PM
  8. JOrtenzi's Avatar
    yep.... just what I thought.... unzip to get the icon files, put the icons on your SD card, and then you can use them as your LP dock icons
    03-24-2011 06:00 PM
  9. cwd500's Avatar
    i just flashed va green theme and apps on 2.9.2 and everthing seems to be working fine.
    03-24-2011 06:02 PM
  10. cwd500's Avatar
    i got the icons for va green. that was easy and it looks even better now!
    03-24-2011 06:24 PM
  11. vjoaquin's Avatar
    JaeKar (or anyone else),
    I extracted the 'bootanimation.zip' file from Adryn's SC 2.9 voodoo zip with the intention of copy/pasting it into the 'system > media' folder on my phone.
    I renamed the current boot file in that folder to 'bootanimation.zip.old' then pasted Adryn's boot file.
    After rebooting, instead of seeing that great exploding honeycomb animation, all I saw was the word 'ANDROID' on the screen in landscape view with some highlighting animation... not what I expected!
    Was I supposed to flash Adryn's bootanimation.zip with CWM or did I do something else wrong? DroidXcon seemed to think it has something to do with VooDoo and said to ask you or Gunnermike...
    Thanks for any guidance!
    - Vince
    03-24-2011 11:05 PM
  12. fitti28's Avatar
    Your preview links for EB01/EB16 Nitro's Ultimate Honeycomb v3.1 - (SC 2.9.2 Ready) come up on XDA as invalid. Just wanted to let you know
    JaeKar99 likes this.
    03-24-2011 11:10 PM
  13. Landshark's Avatar
    Hi putney. Sorry, I was stuck at the office late. If you want to go back to your old theme, best way would be to boot to recovery, wipe cache partition, wipe dalvik cache, flash 2.9, reboot phone, wait a minute or two to let it fully load, boot to recovery, flash 2.9.1 patch, reboot phone, wait again, boot to recovery, wipe cache, wipe dalvik, flash old theme, reboot phone.
    You can try simply booting to recovery, wipe cache, wipe dalvik, flash old theme, reboot phone. Depends on which theme has deeper customizations. Old theme has more - no problem. New theme has more - may still have remnants of new theme carry over.
    Also 2.9.2 is out which includes everything from 2.9 and the 2.9.1 patch plus a few other modifications/tweaks. If you want to save yourself the step of flashing the ROM and the patch separately, you could download 2.9.2 to your sd card and flash it through cwm.
    Hope this helps.
    03-24-2011 11:22 PM
  14. joselalo1987's Avatar
    Thanks a lot, just flashed Honeycomb3.1 theme looks awesome.
    03-24-2011 11:29 PM
  15. JaeKar99's Avatar
    - Vince
    Don't flash. This issue has occurred with voodoo boot animation switches in the past. Please check out this post by ragnarokx - He details the issues and a fix... However - I would not flash the boot animation... it will likely need to be installed with method B.
    I looked at the boot animation file in SC 2.9.2 it installs to system/media. - Here is a copy of that exact file. I looked into the VA green theme and the bootanimation.zip file is also in the same directory. As long as all files are in the correct locations you should be seeing the boot.
    Given I do not use voodoo it would be recommended that you check in with gunnermike53 - he has worked voodoo from every angle..
    03-25-2011 05:53 AM
  16. DarkAngel6698's Avatar
    Hello, wast told talk Jaekar about how to go about getting sound for the bootanimation.zip currently running EC10SC292x_DXc.tar.
    The bootanimation displays and works fine except for the sound part of it.
    What can I do to fix it. All files are in the proper places
    03-25-2011 08:12 AM
  17. JaeKar99's Avatar
    There is good news and bad news as far as sound for boot animations;
    Bad news - current kernels do not support the playing of sound during boot animations. (Shutdown sounds are playable)
    Good news
    - Samsung released the source code for new kernel development yesterday.. (for Mezmerize - Fascinate twin) the hope is that new kernels will start to roll out in the next week or so... with that in play we should start to see the capability for boot sounds, voodoo sound, and voodoo graphics enhancements...
    03-25-2011 09:40 AM
  18. ajjohn25's Avatar
    are any of these themes capabile with the ec10 kernel?
    03-25-2011 10:54 AM
  19. JaeKar99's Avatar
    There is no compatibility issues with EC10. - No problems with any of the themes on the links page... The newer themes; identified as having 2.9.2 are using the framework from the SuperClean 2.9.2. You may only notice some artifacts with images... using older themes.
    Flash and Enjoy.
    03-25-2011 11:05 AM
  20. JJHunter's Avatar
    I just flashed Nitrohoneycomb and I'm liking it so far except I'm not a big fan of the way the keyboard looks...Is there any way I can change that back to the stock SC 2.9.2 keyboard?
    Also, If i wanted to go back to stock SC 2.9.2 with no theme, what would be the best way to do that?
    03-25-2011 04:23 PM
  21. cwd500's Avatar
    i have va green on 2.9.2 and i just noticed that in the notification bar it still says 2.9.1.
    03-25-2011 04:26 PM
  22. JaeKar99's Avatar
    I would bet that the va green theme was built on the 2.9.1 framework.. The 2.9.2 ROM is still there.
    03-25-2011 04:40 PM
  23. JaeKar99's Avatar
    To get back to stock - You should restore your nandroid back up of the ROM before you flashed your theme... it is recommended (strongly) that you do a back up of your ROM prior to flashing your theme of choice.
    Worst case scenario is to clear caches (Dalvik and partition) then reflash 2.9.2. That will take you back to stock without any loss of data.
    03-25-2011 04:46 PM
  24. JOrtenzi's Avatar
    Hey JaeKar...I tried a nandriod restore earlier today, but ended up in a boot loop. When I asked about it, gunnermike informed me that restore in CWM is broken and is being fixed. I am assuming there is no other way to restore your nandriod back-up excpet through CWM, is that correct?
    03-25-2011 04:53 PM
  25. JaeKar99's Avatar
    You (and gunnermike53) are correct. If you tried to restore a backup that is themed it will not restore. Some base ROMs will not restore either but there has been better luck without the theme added in..
    If you backup your freshly flashed base ROM un-themed - it will usually restore. Gunnermike53 has suggested: flash a theme over a theme to remedy the problem - I have had mixed success with that technique.
    I keep a copy of the base ROM (SC 2.9.2) backed up and a copy of the zip on my sdcard. If I flash a theme I choose to revert back I will go with the backup in a pinch... There have been times that it will not restore..
    If it will not restore I will clear both caches and flash the ROM back on - Either way - it takes the same amount of time.
    Landshark likes this.
    03-25-2011 05:00 PM
1,056 ... 23456 ...
