[How To][Links] Themes, ROMs, Kernels, Boot Animations: 9-16-11
JaeKar99
1,260
712
[How To][Links] Themes, ROMs, Kernels, Boot Animations 10-24-11
Primer: Welcome to the Top Post of the Themes, ROMs, Kernels, Boot Animations/Combined Resources thread. The goal of this thread is to help posters find the links, and help needed to get all they can from their phones. If you are new to this forum and are not exactly sure what you want to learn or need some pointers before taking the plunge; please consider starting here: [How To] First time rooting walk-through.
Resource Locater Index:
Post #2 - Theme Principles and Instructions for Installation
Post #3 - Theme Links
Post #4 - Current 2.3 & 2.2 ROMs and Working Kernels
Post #5 - AOSP, MIUI, and other MTD Themes
Post #6 - Addons, Patches, Apps and Eye Candy
Post #7 - Boot Animation Installation Instructions
Post #8 - Boot and Shutdown Animation Links
Post #9- Changing out Icons
Post #10 - Boot and Shutdown Sounds
Post #11 - Live Wallpapers [How to Make them] - in process
Post #12 - Links to Clockwork Mod Recoveries (old and new)
More Resources:
Samsung Fascinate Tools and quick links - DroidXcon
[GUIDE] Fascinate Beginners rooting - Must read for starting out.
[Odin] Froyo leaked packaged custom ROMs w/root and clockwork
[How to] Install and Use Clockworkmod Recovery w/Screen captures
[How To] Use Voodoo kernels
[How To] [Discussion] Improve Battery Life
[Guide] Apps that are safe to remove once rooted
JaeKar99
1,260
712
Theme Principles and Instructions for Installation~ Updated: 5/29/11
Theme Install Instructions:
General principles & Instructions:
1. Make certain the theme you have chosen is developed for the ROM you are currently running. Theme makers will design themes with specific ROMs in mind for proper fit and function. ROM examples: DarkREVENGE, AOSP, Kaosinate, Vanilla Froyo, MIUI, Blackhole 4.x, Superclean 2.x, etc. Flashing a theme on an incompatible ROM can (will) cause some rather disastrous outcomes. I try to make sure that all this information is specified on the download page – if it is not there click the link in the developer name. This will take you to the developer page and there will be more details.
If you are just starting out and need clarification on flashing or CWM Sheepdog Elite - has put together a fantastic thread to help. -> link - Most recent CWM Recoveries are listed here
Download and Installation Instructions:
1. Once you have established your ROM you have and the theme you want match up. Ensure that you have either the red or orange CWM depending on what is asked for by the theme maker (red should work well for the time being). Download that theme to your computer.
2. Then attach your phone via the usb cable and connect usb storage via the phone.
3. Copy the downloaded theme zip file to your sdcard.
4. When the copy is completely loaded to the phone disconnect and boot into recovery.
5. Back up your current ROM… This may be necessary for restoration given the phone does not boot properly (or at all) after installation of the theme.
6. Once back up is complete you may choose to clear your cache partition and/or the Dalvik cache. There are some who choose not to do this step and have not suffered any unpleasant outcomes.. (and others have their phones become bricks).. It is at your discretion. However, it is recommended by many theme builders.
7. Once you choose to clear cache (or not) – navigate to install zip from sdcard.
8. Navigate to the location where you saved the theme zip file on your sdcard.
9. Install the zip.
10. If you get the error “script not supported or outdated” the theme is using the older Amend script and you are using the newer CWM orange – you need to boot into CWM red to get the theme to apply.
11. Once the file has installed return to the main menu and reboot phone. It will take about 2-4 minutes to reboot be patient.
Flashing Theme over Theme: - Updated
This action is typically not a problem. Please keep in mind there are some theme developers that will theme a few applications or just a few parts of the ROM (shallow theming), and there are some who will theme almost all aspects of the ROM and will add custom animations and transitions (deep theming).
The more involved (deeper) themes will be larger in size (85 megabytes vs. 33 megabytes) and the developer will have usually a list of apps that they have modded on their development thread ( please check developer name for link). If you are considering a theme flash that is going to apply a shallow theme over a deep theme you will likely get remnants of the deep theme. Multiple flashes of the lesser theme will not remove these artifacts.
To fully remove all the artifacts you will need to clear your caches (dalvik and cache partition) and re-flash your base ROM to replace all the applications, framework files, and other themed components. Let your base ROM fully reboot and install before you flash the theme - if you do not; you will encounter a bootloop requiring a battery pull and you will have to start over by entering CWM by (power+vol up+ vol down) then reflash your base ROM again, and let it completely reboot. Boot into recovery then install the theme of your choice. If you are going to put a deeper theme over a shallower theme you should experience no issues of artifacts or remnants.
Some Cautions:
Some users (me) have experienced odd behavior from the phone after flashing many (3+) themes consecutively. These side effects are: phone contacts self-delete and force close when you try to access them. Best case scenario: Flash a new theme.. Worst case scenario: This will require a D-cache wipe and base ROM re-flash. This does not appear to be as frequent now that ED01 is now released, the new CWM 3-30, and many more are out.. Please post if you continue to have these issues.
Always keep in mind there is a way out if things get really bad. – Please read and review this thread: Samsung Fascinate Rooting, EB01, Return to Stock, Remove System Apps, Other How-To
JaeKar99
1,260
712
Theme Links - Updated Daily.
Warning: Upating to CommROM 2.1 will clear some of your theme elements.. All themes that are listed here for CommROM 2.0 will NOT work on CommROM 2.1 (expect boot loops)..
2.3 Themes
TSM Resurection Black Alien - gunnermike53
Preview 1 - Preview 2 || Download
TSM Resurection Pinkie - gunnermike53
TSM Resurection Blue Midnight - gunnermike52
2.2 (Froyo) Themes: –(Arranged by Developer name)
notta:
ED05-Powerwash -Port Inspired NeonBT WIP - notta - Updated: 9/15/11
Preview 1 - Preview 2 - Preview 3 || Must see Developer page for download links and install instructions.
Bigloof:
ED05 [Powerwashed Only] Midnight / Steel Blue - Bigloof
Preview 1 - Preview 2 - Preview 3 || Download
kenesis:
ED01 ComROM ~ 2.0 *Transparent-Myst * - kenesis - Link updated: 6/15/11
makav3ll1 (aka TheMuffStuff):
ED01 Miui Inspired TMS (Evil Fascination only) - TheMuffStuff
ED01 ComROM ~ 2.0/EF 3.6Fascinating Charge 2.0 - makav3ll1 - Updated: 6/03/11]
Preview 1 - Preview 2 - Preview 3 || Download for CommROM - ||- Download for EF
ED01 ComROM ~ 2.0 - Fascinating Xperience 2.0 - makav3||1 - Updated: 6/4/11
ED01 Evil Fascination ~ 3.6 BlurWiz v2.0 - makav3ll1 - Updated: 7/22/11
ED01 CommROM LgWiz 1.0 - makav3||1
thefunkbot:
ED01 Community Rom~2.1 TouchWiz4 v3.0 - thefunkbot - Updated: 6/22/11
Preview 1 - Preview 2 - Preview 3 || Download - TouchWhiz status bar -||- Download - black status bar
ED01 Community ROM~ 2.1 Crysis Revolution v4.0 - thefunkbot Updated: 6/20/11
Preview 1 - Preview 2 - Preview 3 || Downloads: Circle Batt -||- Reg Batt
gunnermike53:
ED01 Comm ROM~ 2.1 Yellow Version 1.0 - gunnermike53 - New
ED01 Comm ROM~ 2.1Pinkie Version 1.0 - gunnermike53 - New
ED01 Comm ROM 2.0Glowing Blue Style 4.0 - gunnermike53
Preview 1 - Preview 2 - Preview 3 || Download v4.0
ED01 Comm ROM 2.0 White Chrome v3.0 - gunnermike
ED01 CommROM~ 2.0 Fascinate Detox 2.0 (port) - gunnermike53 - Updated: 6/05/11
ED01 Community ROM~ 2.1 GM53 DiddyRemix Version 2.2 - gunnermike53 - Edify- CWM 3.0 only- Updated: 6/24/11
ED01 Community ROM~ 2.1 Black Alien Version ~ v 4.1 - gunnermike53 - Updated: 6/23/11
ED01 Community ROM~ 2.0 Red Volt v 3.0 - gunnermike53 - Updated: 6/09/11 - Errors Corrected Framework folder
Preview 1 - Preview 2 - Preview 3 || Downloads: Theme -||- Wallpapers
ED01 Community ROM~ 2.0 Blue Midnight v3.0 - gunnermike53 - Updated: 6/03/11
jspidah:
ED01 Community ROM~ Minimalist Stock or Acc Batt - Newest CWM 3.0.2.8.x.ti
Preview 1 - Preview 2 - Preview 3 || Downloads: CWM 3.x -||- CWM 3.0.2.8.x.ti
sunder74:
ED01 CommROM ~ 2.0 Fascinate_EnV - - sunder74 - Updated 6/13/11
nitsuj17:
ED01 CommROM ~2.0 - Sense Enhanced V4.1 - nitsuj17 - Updated 6/14/11
Preview 1 - Preview 2 - Preview 3 || Download -||- 4.1 Patch (new pulldown icons)
MIUIwiz 1.0 ONLY GingerWiz V1 - nitsuj17
Updated 5.16 Miuiwiz beta test available...in rom form - nitsuj17
Preview 1 - Preview 2 - Preview 3 || Download - - - - {Icon Themes} MIUIWiz - link to icons page.
nitroglycerine33:
~~ ED01Nitro Honeycomb v4.3!! - nitroglycerine33 Updated: 5/31/11
Preview 1 - Preview 2 - Preview 3 || Download - TSM Parts Patch
GrainOsand:
ED01 CommROM ~ 2.1 HighVoltage_Renergized_V2.0(TW4 Launcher) - GrainOsand - Updated 7/11/11
Preview 1 - Preview 2 - Preview 3 || Download - Updated with Pandora and GVoice
ED01 CommROM ~ 2.1 TeamCarbon/BigLoofs_STEEL BLUE V3.1 - GrainOsand - Updated: 6/25/11
Preview 1 - Preview 2 - Preview 3 || Download (Theme will overwrite Swype Beta)
Theming Addons:
[HOW TO] Changing out themed Swype - Lttlwing16
Please see link in developer name for instructions and downloads.
Older Themes Moved Here
AOSP and Kaosinate ROMs & Themes moved to Post #3 -> here
Boot Animations & Shutdown Animations have moved to -> Here
JaeKar99
1,260
712
Current 2.2 & 2.3 ROMs, Kernels & Radios
2.3 (Gingerbread) ROMs
EH03 Full Verizon ROM - nitsuj17
Now with a SuperClean version.
Fully Bloated and Binged... not rooted.. See link in dev name for downloads, and install instructions.
EI20 GeeWiz 2.0 *BETA* EI20 TouchWiz Debloated - djp952
Initial Release - see links, instructions and install via the dev link..
Vicious-MIUI-FascinateMTD-1.10.7 - DroidVicious
EI20 TSM Resurrection 1.0 (touchwiz4/tsm parts) - nitsuj17
IFollow UP Release - see links, instructions and install via the dev link..
EH09 based 2.3. PWGB v2.0b2 TW-Based - ccampos784 - Updated
Please see link for instructions, downloads and known bugs.
TSM Pool Party 1.4 (MTD) - sbrissen
Please see link in developer name to obtain links and install instructions.
Biffmod Fascinate v1.3 - 2.3.5 AOSPish - infinitybiff
MTD Vanilla Gingerbread v7 - jt1134
Please see link in developer name for download, install instructions. V2 Now available via ROM Manager - yes it works with MTD ROMS - Updated: 8/30/11
EC09 ComRom GB 0.1 (ugb) *initial release* - nitsuj17
Please see link in developer name for download, install instructions and WARNINGS. Updated patches: 7/13/11
[ODIN][Released by p3droid] Leaked Gingerbread EC09 Full Stock package - DroidXcon
It appears that Ginger-Break v1.2 will root this version - Link
EC09 NAMELESS v4.1 - based on EC09 Gingerbread Leak - navenedrob - Updated: 4/21/11
Download - Must see OP for instructions and install.
EC09 TechnoROM v1 test [based off of NAMELESS] - jptech7
Download - Must review OP link in developer name for installation instructions.
CyanogenMod 7. Build 11 - - 7/17/11 - jt1134
Please see instructions for download and install on the developer page (name link). Final Working Build!!
{AOSP}{Custom Gingerbread}OMFGB 1.3.0 Nightlies - r2DoesInc
[ROM] MIUI FascinateMTD 1.7.22 - andmer
2.2 Roms
[ODIN][CWM]ED01 Stock ROM/Kernel/Recovery - imnuts
Offering an update for those who need a quick way back to ED01.. see link in dev name for downloads and options.
ED05 "GeeWhiz" v.1 TouchWiz Debloated - djp952 - Updated 8-19-11
Please see developer link in name for installation, downloads and instructions.
ED05 - Powerwashed (Final) and Debloated Touchwiz ED05 ROM - ccampos784 - Updated: patched to v 1.1
Voodoo version of ED05 - see links in developer post for downloads and install instructions.
ED05 - VzW full factory froyo restore with radio and kernel - pentafive
This is a 7zip file. you will need to download - unzip (extract) then flash the file in ODIN. Download
This file also contains the Samsung drivers.
ED01 CommROM v2.1 (patch update) - nitsuj17 - Please see download link (developer name for install instructions. - Updated: 6/20/11
This ROM requires: Full data wipe, Dalvik wipe, cache wipe.. prior to install to avoid possible issues.
CommROM 2.1 Patch - No wipe needed. Must be flashed over CommROM 2.0
Full Roms w/ Kernels:
UKB 2.0 with -50 PBJ Voodoo Kernel - Script corrected. 6/4/11
md5: 1092A4F02F668521D633670A80BA127C
UKB 2.0 with -100 PBJ *6.4.11 (many phones cannot run this kernel)
md5: 369579739FF3CA10144300B78BFBCC9C
UKB 2.0 with OTB 1.5 Voodoo Kernel
md5: 5118f303b7b32c080c1a7331ca34b936
Full Roms (no kernel)
UKB 2.0
md5: 6e982ed5c98f25383fc80ce1fd48bc6d
[ED01] MIUIWiz - 1.1 - nitsuj17 - Updated: 6/07/11
This is a themed ROM.. Preview 1 - Preview 2 - Preview 3 | | Download and install directions -> Please seek link in developer name.
[ROM] [CM7] [GINGERBREAD] Kaoscinate V7.0. - - punk.kaos
Must read the install instructions on the developer OP.. There are still errors and FCs must read and follow instructions.
ED01 Evil Fascination Version 3.6 ROM - nitroglycerine33 - Updated: 5/26/11
See link in developer name.. for download and install instructions.
ED01 Community ROM (aka Kangbang) - Adrynalyne - Updated: 5/07/11
Download - Instructions on developer OP... Voodoo ONLY - Please validate that the size of the download - getting errors from this download site.
Download Mirror -||- TouchWhiz Calendar notifications may cause FC issues - calendar patch -||- Patch 1.2 (requires CommROM 1.0) -|||- Does not require 1.0: Full ROM 1.3
ED01 Stock - Rooted/ED01 Debloated/Debinged - Adrynalyne
Download (does not have Radio, CMR, or kernel) || More Debloated and DE-Binged : Download II - Not fully tested (does not have Radio, CMW, or Kernel)
Get to ED01 (Official Froyo) Quickly - See Post in developer link - Adrynalyne
Gingerbread Themed Aosp (full ROM) - OldManJames
Preview 1 - Preview 2 - Preview 3 || Downloads/instructions - See link in developer name.
Flashable Radio/Modems - Updated: 6-09-11
Please read, understand and follow the instructions in the original - > Link
Updates to ED04
Available Radios: Links - nitsuj17
ED05
EC01
EB01:
DL09
DJ05
DJ05 Backup
DI01
2.3 Radio EC09
2.3 Kernels:
CM7/MIUI Glitch V12 Beta -1.7GHz OC/UV-Voodoo - sixstringsg
See Developer Link for downloads and install instructions.
[cm7 or miui] OTB (fascinatemtd) - nemesis2all
Please see instructions for download, performance and install on the developer page (name link).
OTB 2.6.35.7 CFS 0704
OTB 2.6.35.13 CFS 0704
[CM7/MIUI][16/07/11] Glitch V12 Beta -1.7GHz OC/UV-Voodoo-Smooth and fast - times_infinity - Updated: 8/27/11
2.2 Kernels:
ED01 OC UV Voodoo EnderstSpecial Froyo TouchWiz based -nemesis2all - Updated 6-01-11 - (All Overclock warning apply)
Voodoo - Enderst Special - Undervolted -50mv and Overclocked to 1.2 GHz
Voodoo - 4/7 Standard voltage - Overclockable
Voodoo - Test 4/7 Overclockable to 1.2 and 1.3GHz
Voodoo - OTB (TouchWiz CWM3 Voodoo OC adjustable) - Warning: Must read post for install and use! - Updated.
Voodoo - OTB (Reloaded) - Updated: 4/20/11
Voodoo - OTB Version 1.2 (CWM 3) installed.
Voodoo - OTB v 1.3
Voodoo - OTB v1.4
Voodoo - OTB v1.5
Voodoo - OTB v1.6
PW-OTB Fusion Kernel (08-15-2011) - Voodoo Only.. ccampos784
ED01 Kernels - PeanutButta Jelly Time - imnuts - Updated: 8/08/11
PBJT - Voodoo 8/8 Final - May Correct Missed Call Issue
PBJT - non Voodoo 8/8 Final - May Correct Missed Call Issue
5/30 - Voodoo - Standard Voltage
5/30 - Voodoo - (-50mv)
5/30 - Voodoo - (-100mv)
5/30 - NonVoodoo - Standard Voltage
5/30 - NonVoodoo - (-50mv)
5/30 - NonVoodoo - (-100mv)
EC01 Kernel For TouchWiz - jt1134
Voodoo - Updated 4/16/11
Non-Voodoo - Updated 4/16/11
EC10 Kernels with (dummy tether module) - Adrynalyne
Voodoo Non-Voodoo
EB16 Kernels with (dummy tether module)- Adrynalyne
Non-Voodoo Voodoo
EB01 Kernels:
Voodoo Non-Voodoo
Needing advice on Voodoo? - check out -> How to Voodoo (gunnermike53)
If you are just starting out and need clarification on flashing or CWM, Sheepdog Elite - has put together a fantastic thread to help. -> link.
Boot Animations Installation Instructions and Links can be found -> here
DL30 Roms and Themes moved -> - Here
DJ05 and DL09 - ROMs Themes and Kernels Link
JaeKar99
1,260
712
AOSP, MIUI, and other MTD Themes, Updated: 9/17/11
Themes for CM7 and AOSP, MIUI, and other MTD builds: - UPDATED: 9-17-11
CM7 Themes List - maxpower47
Please see thread for links and install instructions.
Pulldown Toggles For JT's Vanilla GB [Build GRJ90 0811] - chopperthedog
Preview || Download
Cleanest Transparent Gray Vanilla GingerBread 2.3.5 ROM - DevinLeFevere
'MURDER' for JT's Vanilla GingerBread 2.3.5 ROM - Preview 1 - Preview 2 - Preview 3 || Downloads available via developer link.
'BLIZZARD' - for JT's Vanilla GB 2.3.5 rom - B-boy?
BLIZZARD for JT's version 7 Vanilla ROM - REMIXED and TRANSPARENT - B-boy?
Preview 1 - Preview 2 - Preview 3 || Download available via developer link
Chopper's Mash Up For Vanilla GB [Build GRJ90 V3 080411] - chopperthedog
"FUSTER CLUCK" - for JT's 2.3.5 Vanilla GingerBread rom - B-boy?
Preview 1 - Preview 2 - Preivew 3 || Downloads available on the developer page
JaeKar99
1,260
712
Addons, Patches, Apps, and Eye Candy - Updated: 7/09/11
Addons; Patches; and some Eye Candy:
EC09 (2.3) - SB Mods/TSM Parts - sbrissen
Please see link in developer name for downloads and install instructions. EC09 warnings apply (sdcards may become toast).
Themed Dropbox Icon - Lttlwing16 - This is an .apk file - copy to sdcard and install - Download
How to Update to Swype 3.0 (beta) - tonu42
See instructions in developer link.
Amazon Kindle Apk for use on CommROM if the market version FC's.. - Download - Install by placing on sdcard and using file explorer to install.
Power to Search Button/Added Camera[All TW blds] - chopperthedog
Please see post in developer name for downloads and install instructions.
EC01 ED01 - Sbrissen Mods / TSM Parts 1.0 - sbrissen - Updated: 6/08/11
Please see link in developer name for information and install instructions.
Whats included: No Full Batt popup, Reboot options, Clock Options, Acc Batt., 6 Lockscreens, Music controls, AOSP Phone answer,.
Themed Launcher2.apk (CommROM launcher) - representingcochran
Edify Flashable Zip -> Link
Car Dock and Amp - Edify Flashable Zip - > Link
Themed Swype Keyboard - kenesis
Currently not fully compatible with CommROM 1.3 see - [HOW TO] Changing out themed Swype.apk
Wallpaper Super Pack (122 Walls) - JaeKar99 - DO NOT flash this zip.. open on computer and transfer to phone.
Download - A collection of wallpapers from current and defunct themes, Android related, colorful backgrounds, and some odds and ends.. completely family suitable.
Wallpaper Super Pack II (84) More walls - JaeKar99- DO NOT flash this zip.. open on computer and transfer to phone.
Download - Collection of darker Android images and some cool outside landscapes.. completely family suitable.
Additional Add-ons for ED01 ? These are Edify (CWM 3.0.2.7x) - nitroglycerine33
Mobile IM Download
Nuance Voice Commands
Visual Voice Mail
Samsung MMS App
Talk Back
Thinkfree Office
Touchwiz Launcher
Touchwiz Wallpaper Chooser
Touchwiz Widgets
Memo
Write and Go
Samsung Media Hub
Pro Tips
Samsung Live Wallpapers
AOSP Desk Clock - Flashable - - imnuts
Download
ED01 and EC01 SGS2 TW Launcher - sbrissen
Video Page || Download
Clockwork Mod Recovery v3.x with voodoo- Edify - times_infinity
Downloads: CWM 3.x.zip || Odin CWM 3.x - Use only if you are planning to start flashing Kernels, ROMs, Themes, and other items that have been labeled as "Edify", "Flash in CWM3" - or "Orange Recovery" - This version does not support Amend Scripts.
EC10 - Froyo TW Samsung *v3.0* DeliveryReports/"Screen On"Notif/SMStoMMS - GizmoDroid(1) - GizmoDroid
Download - See info developer links..
300 Flashable Font Packs - Change your system fonts the easy way! - fachadick
Must read and follow instructions on the developer page (downloads located there) See link in developer name.
EC01 Battery Mods - sbrissen
Accurate Battery || Stock Battery
Samsung Boot Logo Mod (Not bootanimation, SAMSUNG power on logo) - kmalinich
Please see link in developer name for installation instructions and image links.
EC10 (Mesmerize ROM) - Nameless_v3 Accurate Battery 3 Apr 2011 **Beta4 - gunnermike53
Download
[Mod] Froyo Samsung Car Cradle (Works With AOSP Player/Pwramp/Pandora/AG) - Adrynalyne
Please see link in Developer name for download links and install instructions.
Collection of TW Mods/Improved TW Experience - CrushD
Please see link in developer name for instructions, downloads, and features.
MOD:Settings (Calibration, Stay Awake, DUN) - Adrynalyne
ScreenShots: 1 - 2 - 3 || Downloads: Stay awake -||- Settings Mod
EB16 v2.0* Froyo TW Samsung-SMS Delivery Reports/"Screen On" Notification/SMS-to-MM - GizmoDroid - Updated: 3/3/11
Please read details of fix in the developer name link.
EB01 Experimental Battery-Mod-Automator - Chris3D
New Option - Instructions and details included. See link in developer name.
Getting Hulu to work on Fascinate for Froyo -DroidXcon
Please link in developer name for instructions and downloads. - Updated 2/24/11
JaeKar99
1,260
712
Boot Animation Installation Methods A & B:
Boot Animation Installation Method A: Flashing in Recovery
Use this method only if instructions read “Flash in Recovery” – if it is not specified you will need to use method B. – If you are not familiar with using Clockwork Mod Recovery please see this review: [How to] Install and Use Clockworkmod Recovery w/Screen captures (DroidXcon)
1. Boot into recovery. – CWMRed will likely be required due to the age of the boot animation and that the script has not been updated.
2. Note these files are rarely named “bootanimation.zip” they are typically named to indicate the name of boot animation by the developer.
3. Select install .zip from sdcard then choose zip from sdcard.
4. Select “yes”. Note if it does not flash or gets hung up it is a zip file that is not developed to be flashed. You will need to use Method B.
Boot Animation Installation Method B: Manually replacing the bootanimation.zip (intermediate)
1. Download and copy the “bootanimation.zip” file to your sdcard. – If the file you downloaded is not labeled bootanimation.zip the kernel will not recognize it and it will not play when the phone is booted. Renaming to “bootanimation.zip” is easier on the computer and you may want to do that renaming before coping to sdcard.
2. You will need a file manager with super user permissions and rights. There is a couple on the market – Root Explorer or Super User. Must ensure that R/W is enabled. I am using Root Explorer in these images.
3. In the file manager navigate to the system/media folder (root of the phone) you will see a file named “bootanimation.zip”. Rename it “bootanimation.zip.old”. Or delete it. You can always re-flash the base ROM.
4. Using your file manager navigate to your sdcard and find the bootanimation.zip file and copy it..
5. Navigate back to your system/media folder on the root of the phone and paste the file. You should see the file in the directory. If the file manager did not copy the file.. you do not have the file manager set up for r/w capabilities.
6. Once you have the file in that location you should see your new boot animation when you restart your phone.
7. Restart your phone. You may need to restart twice for the animation to work.
You now have a new boot animation installed.
Overlapping Boot Animations (explanation and fix):
1. When looking into the folders in the root of the phone: the stock boot animation file will be a single qmp file, labeled "bootani.qmp". A custom boot animation will be labeled "bootanimation.zip" - There are also reports of files named: bootsamsung.qmg and bootsamsungloop.qmp that willl also overlap.
2. When flashing or installing kernels that are looking for either of these two files if both are present you will see two different boot animations.. they will overlap each other. If both are missing you will get a sideways "Android" text page during boot because the kernel is looking for a boot animation file and cannot locate it.
3. (the fix) If you have this event take place do the following to correct it: 1. Delete the bootani.qmp file in system/media, & 2. Install a custom bootanimation.zip file, installing it to that location.
How to change a Shutdown Animation: (Very Basic): More details pending
1. Unless it specifies (Flash in Recovery) Shutdown animations must be copied/moved or pushed to the phone into the correct directory.
2. Info: These (zip) files contain a series of image files 'png' and they are numbered sequentially what gets played fist -> last.. you can unzip the shutdown.zip file(usually another folder labeled 'Shutdown) and copy all the contents or that folder directly to that folder in the "system/media/video/shutdown" on the phone.
Replacing the old folder with the new folder and contents.. Keep in mind that many ROMS and Themes do NOT have shutdowns and this folder may not exist and you will be required to make this folder and copy the shutdown into it..
Keep in mind if you look inside a Theme or ROM and you find the folder structure system/media/video/shutdown that ROM/Theme does have a shutdown - and you can extract it, remove it, or replace it with the one you want.
JaeKar99
1,260
712
Boot and Shutdown Animation Links. Update:~~ 10/07/11~~
Boot Animations:
MIUI (mtz) - Import via theme manager/engine from sdcard. New: Still image previews should now be available.
Ice Cream Sandwich (Nexus Prime Boot) - Westi01 ported by JaeKar99
Animated Preview || CWM Download || CM7 (mtd) || MIUI (mtz)
Liquid Honeycomb - JaeKar99 – New
Blue Hole (like Black Hole) – JaeKar99 – New
Animated Preview || Download CWM || CM7 (mtd) || MIUI (mtz)
Blu Plazma II – JaeKar99 – New
Flyin Vs – JaeKar99 – JaeKar99 – New
Pool Party (mtd only) – JaeKar99 – New
Quake – JaeKar99 – New
Resonance – JaeKar99 – New
Simpsons Kanged – JaeKar99 – New
Speedo II – JaeKar99 – New
Andromeda - JaeKar99
Animated Preview || CWM 2.x and Up || CM7 Install || MIUI (mtz)
Blue Hallway - JaeKar99
Bubbles - JaeKar99
Glass Rings - JaeKar99
Countdown~2~Droid - JaeKar99 - End loops with spinning Droid.
Colour DNA Boot Animation - JaeKar99
Animated Preview || CWM 2.x and Up || CM7 Instal || MIUI (mtz)
Pyral - JaeKar99
MachinAzul - JaeKar99
Red Hex Tunnel - JaeKar99
M-FraClock - JaeKar99
Red Binary Boot Animation - JaeKar99 - New
Animated Preview || CM7 Install || CWM 2.x and Up
Warp Vortex Boot Animation - JaeKar99 - New
Molecules Boot Animation - JaeKar99 - New
Animated Preview || CM7 Install || CWM 2.x and up
Red Vortex Boot Animation - JaeKar99 - New
Jolly Roger Boot Animation - JaeKar99 - New
Android Blues Boot Animation - JaeKar99 ~~ CM7 install only
Clock Gears III Boot Animation - JaeKar99 - new
Animated Preview || Download - Flash in Any CWM
Dolby Countdown Boot Animation - JaeKar99 - new
Animated Preview || Download - Flash in Any CWM || CM7 Install
Dolby in the Dark Boot Animation - JaeKar99 - New
Animated Preview || Download - Flash in any CWM [Click for QR code] || CM7 Install
Honey Bee (Honeycomb Boot Versions): (these boots are designed for a different device but have been formated to center on the fascinate)..
Honey Bee Blue Boot Animation - Android Shared
Honey Bee Green Boot Animation - Android Shared
Honey Bee Red Boot Animation - Android Shared
Fourth of July Android America Boot Animation – JaeKar99
Animated Preview || Download – Flash in any CWM
Android + Linux Boot Animation – JaeKar99
Purple Hazze Boot Animation – JaeKar99
Hyper Space Loading Boot Animation – JaeKar99
Blue Droid Eye Boot Animation - GrainOsand did the color mod, I assembled.
Electric Blue Honeycomb - GrainOsand did the color mod, I assembled.
Flaming Blue Skull Boot Animation (by request Color Mod) - JaeKar99
Animated Preview|| Download - Flash in any CWM
Bubble Pop - Boot Animation (HD) {very large file size} - JaeKar99 - New
Alice Through the Looking Glass - Boot Animation (HD) {large file size} - JaeKar99 - New
Ring Dream (Blue) - Boot Animation (HD) - JaeKar99 - New
Elegant Android Boot Animation - Jaekear99
Generation X - Boot Animation - Goldie - Optimized and repacked by JaeKar99
Modern Warfare 3 Boot Animation - Cred: sheanzyy- Repacked and resized for the Fascinate. XDA Cover Link
Tool Band Tribute Boot Animation - JaeKar99 - New
AeNomloy (odd energy shape) Boot Animation - JaeKar99 - New
EMS Tribute Boot Animations (as per request) but not downloaded - JaeKar99
#1 - Preview || Download - Landscape Display
#2 - Preview || Download - Portrait Display
Modified Dinc Boot Animation - JaeKar99 - new
Scrolling Lines of Code Boot Animation - JaeKar99 - new
Blooming Rose Boot Animation - JaeKar99 - new
Popping Bubble Boot Animation - JaeKar99 - new
Ghost of Havoc Boot Animation- JaeKar99 - new
Animated Preview || Download - Flash in CWM 2.x or 3.x
Android vs Apple III - Boot Animation- JaeKar99 - new
Animated Preview || Download - Flash in CWM 2.x or 3.x (new upload - suspected corruption in the file)
Boot-y - Boot Animation (done as a joke) - JaeKar99 - new very limited release
Android Crumble Boot Animation - goldie - New
Animated Preview || Download || CM7 Install
Google Shudown Animation (with sound) - from CommROM - repacked..
Galaxy S BIOS - Boot Animation - JaeKar99
Animated Preview || Download - Flash in CWM 2.x or 3.x || CM7 Install
Android Zapps Apple (side on) Boot Animaton - JaeKar99 (per request)
Animated Preview || Download - Flash in CWM 3.x or
Bubble Android Boot Animation - JaeKar99
Animated Preview || Download - Flash in CWM 3.x or 2.x
Liquid Havoc II Boot Animation(next installment in the Havoc family) - JaeKar99
Hairy Havoc Boot Animation (saga continues) - JaeKar99
Final Havoc Boot Animation (the end - Fixed) - JaeKar99
Liquid Havoc (Wild Cousin to Blue Havoc) - JaeKar99- re-edited to improve video flow
Animated Preview ||Download - Flash in CWM 2.x or 3.x
Blue Cross Boot Animation IV - JaeKar99
Trapcode Boot Animation - JaeKar99
Pacman Boot Animation - Davey11 - Cred: Androidman
Flaming Skull Boot Animation - JaeKar99 - New
Animated Preview || Download - Flash in CWM 2.x -||- Download - Flash in CWM 3.x
Zombies in the graveyard: 2 kinds - Repack by JaeKar99.. newish
On a Black Background: Animated Preview || Download - Flash in CWM 2.x -|| Download - Flash in CWM 3.x
On a White Background: Animated Preview || Download - Flash in CWM 2.x -|| Download - Flash in CWM 3.x
Nexus 1 Boot Animation - Reloaded - Thanks weygandttw fits the fascinate better..
Animated Preview || Download - Flash in CWM 2.x -|| Download - Flash in CWM3.x
Shutdowns from the Epic 4G [Port] - optmsprim2 Ported by davey11 - Updated to 3.x - Thanks again davey11
Fuchsia -|| Preview - Flash in CWM
Red -|| Preview - Flash in CWM
Green -|| Preview - Flash in CWM
Blue -|| Preview - Flash in CWM
VRays Boot Animation - JaeKar99 - New
Magic Red Orb Boot Animation (HD) - JaeKar99 - New
The One - Ring Boot Animation - JaeKar99 - New
String Energy Boot Animation - (HD) - JaeKar99 - New
Animated Preview || Download - Flash in CWM 2.x -|| - Download - Flash in CWM 3.x
Sci-Fi Android Boot Animation - JaeKar99
Animated Preview || Download - Flash in CWM2.x -||- Download - Flash in CWM3.x
Android "BIOS" - Fascinate specific/custom! - Protonus - Made Flashable by davey11
Animated Preview || Downloads: Amend -|| - Edify || CM7 Install
Blue Havoc (blue midnight theme - without tags) - JaeKar99
Animated Preview || Download - Flash in CWM2.x -||- Download 2 - Flash in CWM 3.x
Fascinating Vortex - JaeKar99
Animated Preview || Download- Flash in CWM2.x -||- Download - Flash in CWM3.x
Golden-Gears - Jaekar99
Animated Preview || Download - e- Flash in CWM2.x -||- Download - Flash in CWM3.x
Butterflies II - Looped - JaeKar99 - Updated 4/13/11
Android peeing on Apple Boot Animation - JaeKar99
Bokeh Loop - Sense Like boot animation - JaeKar99
Red Flare - Very Basic Boot Animation - JaeKar99
Screenshot || Download - Flash in CWM2.x -||- Download - Flash in CWM3.x
Android Vs Apple Lol - Funny - Odd - charlieb620
Boot Helix Multiple Colors - [Port] Fascinate Logo installed - Hymizzle
Preview (minus logo) || Download Blue - Flash in CWM
Download Red - Flash in CWM
3D CM7BootAnimation Any fascinate rom - tyler1234567
Blue Helix - [Port] Epic 4G - optmsprim2
Red Helix - [Port] Epic 4G - optmsprim2
Green Helix - [Port] Epic 4G - optmsprim2
Fuchia Boot - [Port] Epic 4G - optmsprim2
Alien Head Blue - Goes with the Black Alien Theme (minus the gunnermike tag) - JaeKar99
Alien Head Orange - Black Alien Theme (tag free) - JaeKar99
Butterflies (for the ladies) - JaeKar99
Screenshot || Download - Flash in CWM2.x -|| Download - Flash in CWM3.x
Call Of Android - COA - jonathanmsims
New - from the Mesmerize forums:
Pink Circles: Screenshot || Download
Love (bees/hearts): Screenshot || Download
Chrome: Screenshot || Download
Nexus Boot: Screenshot || Download
Thumbprint of God - JaeKar99
Video preview -
Download - Loops and extends - Flash in CWM - Updated: 4/13/11
Laser Andriod Engraver - cableguy1/wideopn11 - Mod by JaeKar99
Screenshot || Download - Flash in CWM2.x -||- Download - Flash in CWM3.x || CM7 Install
SuperClean 2.x - Electric Purple Honeycomb
Scrolling Numbers - hesh.monster
Download - Screenshot
Nitrovivid Boot Animation - Galaxy S version
Download
Windows Boot Animation for WP7 Revolution (Windows Phone) - lucas.scott
Download
3D Blue Bumblebee (honeycomb)
Preview video | Download
MS Windows Boot:
Win 7 |- Install via Recovery
Call of Android Boot animation - Crackanug
Preview | Download - Use Copy Method
Midnight V1.2 Boot Animation (requested)
No Preview Available | Download
Aperture Science Boot Animation - HardcorePooka (Flash in Recovery) - Fascinate Specific.
Download | Preview Image
Screaming Driod 2.2 Boot Animations -
Download | Preview | Cyanogen
Download | Preview | Unbranded
Halo Reach - Auntie Dot
Preview | Download
Android - Alien Boot Animation
Preview | Download
Carbon Fiber Boot Animation
Preview | Download
Boot Animation - BIOS (Flash in Recovery)
Preview | Download
Thumb Print Analyzer Boot Animation(Flash in Recovery)
Preview -| |- Video(youtube) -|| - Download - Flash in Any CWM
Haters Gonna Hate Boot Animation
Preview | Download
Android Scribble v2 Boot Animations- Lots of versions: (this works well on Fascinate)
Cyanogen-Mod: Preview | Download
Pink: Preview | Download
Red: Preview | Download
Yellow: Preview | Download
Green: Preview | Download
Scribble Shutdown Animations (no preview yet)
Download (Flash in Recovery)
Android scribble w/yellow color burst | Download
Android scribble w/no color burst | Download
Android scribble w/green color burst | Download Preview
R2D2 Boot Animation
Preview
Download 1 (CWM Flashable)
Download 2 (install via copy method)
Android beating Apple with Bat Boot Animation (Flash in Recovery)
Download Link | Preview
Matrix Falling Character Boot Animations (multiple colors)
Matrix Red | Preview
Matrix Blue | Preview
Matrix Sky Blue | Preview
Matrix Green - Preview
Cyborg Boot Animation
Preview Cyborg | Download:Cyborg
Decepticon Boot Animation
Preview Video - YouTube Link
Download: Decepticon
Boing by Qteknology
Preview Boing
Download:Boing
SackBoy Boot Animation[/B]
Preview SackBoy
Download:SackBoy by T2noob.zip
Metropolis by Qteknology Boot Animation
Preview Metropolis
Download: Metrapolis
Green Rage Boot Animation(Red Rage recolored by thenestor)
Preview Green Rage
Download Green Rage
Download: Red Rage
Nexus Preview
Nexus Download
The Droids Boot Animations
Download | Preview AndroidGlow1
Download | Preview AndroidGlow2
Download | Preview AndroidMinimal1 Green
Download | no Preview AndroidMinimal1 Blue
Download | Preview AndroidParticles1 Green
Download | no Preview AndroidParticles1 Blue
Download PreviewAndroidParticles2
Stock Boot Animation (for those who must have it)
Download
Galaxy S Shutdown Animation - Download
JaeKar99
1,260
712
Updated: Icon Replacment - Updated: 5-16-11
Changing Icons in Launcher Pro: - Thanks Lttlwing16
  1. Download the icon or icon folder to the sd card
  2. Check the gallery and ensure the icon can be found (if not, move the icon using file manager to a folder that exists in the gallery, i.e. Photos, or create a folder named Icons)
  3. Long Press on the Home screen you would like the shortcut to appear.
  4. Select 'Shortcuts' from pop up-menu
  5. Select applications
  6. Select application you are trying to create a shortcut for (music, mms, calc etc)
  7. It should bring up an EDIT SHORTCUT , and an option to change the name/icon
  8. Press the icon to change it.
  9. Select the folder in the gallery containing the icon you want and select the corresponding icon
  10. Select OK
  11. Move the shortcut wherever you want it.
Disclaimer:Lttlwing16 or JaeKar99 DO NOT claim any credit for producing these icons. We have simply extracted them from ROM's and Themes so that they may be used across any set up with Launcher Pro. If you want to thank someone for them, PLEASE thank those who themed them or produced them. We just picked them and made them available.
Credits:
Unknown Icon Pack - raadius - Home Screen Layouts (POST ALL HERE) - xda-developers
Samsung Touchwiz
Superfrankenclean 2.9.2 (AOSP icons) - Adrynalyne
http://forum.androidcentral.com/verizon-fascinate-rooting-roms-hacks/65948-rom-superclean-2-9-2-ea15-eb01-eb16-ec10-based.html
Comm Romm/Kangbang (themed AOSP icons)--Adrynalyne/Team Sbrissen
http://forum.androidcentral.com/verizon-fascinate-rooting-roms-hacks/79483-rom-5-07-2011-ed01-community-rom-v1-3-a.html
Nitrodark Honeycomb v 4.2.1--nitroglycerine
[Theme][04/05/11] NitroDark v4.0 - Tested with SC 2.9.2 *Big Update* - xda-developers
Touch of Blurv2.9--sunder74
[Theme][UPDATE 4/21]Touch_of_Moto_GingerBlur_V2.9 [Sbrissen mod EC01/ED01 & EB01] - xda-developers
EC01 Miui/Ginger Hybrid (ec01) - nitsuj17
{Theme}{WIP} updated 5.16 Miuiwiz beta test available...in rom form - xda-developers
ED01 Community Rom~1.3 TouchWiz4 - thefunkbot
[Theme] TouchWiz4 v2.0 *Community Rom 1.3* *5.15.11* - xda-developers
ED01 CommROM ~1.3 TeamCarbon/BigLoofs_STEEL BLUE V1.75 - GrainOsand
**[THEME][Port][ComRomV1.3]TeamCarbon/BigLoofs_STEEL BLUE V1.75**5/12/11 - xda-developers
Now for the icons:
______________________________________________________________________________________________________________
Download Unknown Icons -> Link
Download AOSP Icons - > Link
Download KangBang Icons - > Link
Download Mui Ginger Hybid Icons - > Link
Download NitroDark Honeycomb Icons - Link
Download Steel Blue Icons - > Link
Download Touch of Blur Icons - > Link
Download TouchWhiz Icons - > Link
Download TouchWhiz4 Icons - > Link
JaeKar99
1,260
712
Please keep in mind that the current available kernels (DL30, EB01, and EB16) do NOT support sound when playing boot animations - Shutdown sound does work. This will ONLY apply for EA28, DL09 and DJ05 kernels... More detailed instruction sets are coming.
Boot and Shutdown Sound File Placement/Format:
Startup sound:
1) DL a new sound file. There are a lot of sites on the Internet that will provide free access to many sounds. Freesound is one of them. Registration is required for download. Downloads are in an .aif format.. That will require a file converter (good to have for shutdowns and other sound file modifications).... I prefer Spesoft Audio Converter. Not a lot of bells and whistles, but gets the job done. You can use Winamp+ also.
2) Convert to a .wav file. It may need to be renamed to PowerOn.wav. This is done easier on the computer.
3) Put PowerOn.wave on SD card
4) Open Root Explorer or Super Manager
5) Navigate to /system/etc
6) Rename "PowerOn.wav" to "PowerOn.wav.old" (In the case of some custom ROMS there may not be any PowerOn.wav)
7) Navigate to where you placed the DL'ed .wav file on the sdcard
8) Copy
9) Navigate back to /system/etc folder paste
You have now set up your boot animation to have sound effects.
Shutdown sound: -
2) Convert to .ogg file - rename it 'shutdown.ogg'
3) Put on SD card
5) Navigate to /system/media/audio/ui
6) Rename "shutdown.ogg" to "shutdown.ogg.old"
7) Navigate to the DL'ed/renamed 'shutdown.ogg' file - on sd card
8) Copy
9) Navigate back to /system/media/audio/ui and paste
New Link:
piizzadude was fantastic enough to share a long list of shutdown sounds - > Link - Please remember to thank him {button}
You have now set up your phone to have shutdown sounds
Sample wav files for download:
Verizon Power on Wav
R2D2 1
R2D2 2
R2D2 Long
Emperor Welcome
Windows 95 Start
Whizzz - Android peeing on Apple start up..
JaeKar99
1,260
712
Live Wallpapers - Download and Custom Made
Live Wallpapers:
How to make and install... In progress.
Live wallpapers can be assembled from a collection of png files. For the sake of explanation (png) files are graphic image files. They are primarily used for icons, and other images in the Android software. Many of the boot animations that are listed in this thread are composed of sequential png files that are good candidates for the assembly of live wallpapers.
This post is designed to help beginners to learn how graphic files can be assembled and used to help augment the fun and functionality of their phones. If you are not familiar or comfortable with the use of 7zip, WinRAR, paint, and converting file formats. You should avoid taking this project on until you are more familiar. If you do choose to take this on please share your successes with the rest of the forum.
To begin the development of live wallpapers you will need to download [Live Wallpaper] Custom Creater 2.6 - Daneshm90
Note: This is a zipped file and must be extracted to your computer. It is important that you have some prerquisite software installed: Java in ur environmental path (to check go start -> run -> cmd -> "java -jar" - enter
Do u see "command not found" ? if so go to java.com and install it, otherwise ur fine.
Once you have this installed you will need to become familiar first with the naming convention for the png files: they must start with 'n' (ex. n01.png, n02.png.. n23.png.... n300) -You cannot alter this convention. I have opted to use a separate folder to store these image files until I am ready to move them to the assembly folder. If the boot animation has many files that are broken over two subfolders (part0 and part1) you will still need to name them accordingly and then copy them to the correct file. The max number of image files is 300.
If the files are in that you are going to use are in jpg format - they must be converted to png format. I have used paint to do this and will change the name of the file at the same time. There are programs available for converting if you so desire.
Once you have assembled the image files you will need to copy them to the 'placeimages' folder in the main folder of the live wallpaper creator. - Caution: any leftover jpg files will cause issues (white screens) with the wallpaper as it is displayed. (note: there is a pre-installed boot animation in that folder already) - remove or copy out before you start the batch process.
You can add an icon to the apk – this is done by creating or editing a png image file with your choice of image – size must be 72 x 72 to fit in the location correctly. This must be labeled ‘icon.png’ – only.
Copy the ‘icon.png’ file in the “placeimages” folder with the other png image files.
You will need to count the number of ‘n’ files and this will need to be converted to a hexadecimal sum for the installation process… DO NOT count or include the icon file in the count. – This can be done on many online converters here is a link.
If you use a number (not hex sum) – you will get a white screen upon your attempts to run the live wallpaper.
Having all the files in the correct location, hex number ready, start your live wallpaper builder..
Take your time to fill in the required fields in the command prompt window. Once you have completed the process you will get the developed live wallpaper apk file…
Copy to your phone’s sdcard then install like any other application. Access through the wallpaper settings and adjust size and frame rates..
It will take some time and practice to find, and adjust png files that are the correct size and definition. Be patient. Expect failures. Don’t give up.
Here are some examples of Boot Animations that have been extrapolated into Live Walls:
Electric Purple Honeycomb - Super Clean Boot Animation
Blue Particles - Nitro's Boot Animation
Andi - (Andriod) - Peeing on Apple - Unbranded.
These are .apk files that must be installed via file manager. (copy to sdcard, find with file manager, tap file - install)
Do not flash.
JaeKar99
1,260
712
CWM, Nandroid Restore Fix
Newest Recoveries:
times_infinity
Voodoo CWM 3.x - *last updated 5.8 (version 3.0.2.8.x.ti)
jt1134
[RECOVERY] Updated ClockworkMod for ALL ROMs *last updated 3/30 (version 2.5.1.x) - Append - - Odin File -|| - zip File
gizmodroid
Erasing the CWM Confusion (reference for cwr issues) *last updated 4.8.11 (version 2.5.1.x updated)
tonu42
CWM3 with voodoo *last updated (version 3.x)
Superuser + Busybox zip file - apend flash only..
Superuser+ Busybox - Edify version - Will install Busybox and su..
Jmac9
243
24
So its been over a week since i've flashed or dld anything........itching big time. Has anyone had any luck with the spb mobile app/theme shark found? I can't seem to get it to install off file manager. "parse error".
My new sig is going to be "any ideas what i'm doing wrong"?
Bolt_of_Thunder
211
11
Question about step #5 in post 2.
How do you back up your current rom? I'm on Superclean 2.9.1. Is that when you backup using Titanium Backup or do I need to do something else also? Thanks.
JaeKar99
1,260
712
I had it up for a few before I realized it still needed development. I know a few others had it going as well. I did not encounter that error.
Reactions: Jmac9
putney1477
336
8
If I flash a new theme, and I dont like it, how do I get back to the regular old stock that I had? (whatever came with the 2.2 and sc 2.8 package)
JaeKar99
1,260
712
You will need to use Clockwork to back up your ROM.
Post #6 in this DroidXcon's clockwork thread. That should get you going down the right path.
JaeKar99
1,260
712
Two options: Reflash the base ROM SC 2.8 - Or - If you backed up your ROM prior to the theme flash you can restore that backup..
Word of caution - are getting ready to try out different themes: there is a known issue with trying to restore backups of themed ROMs. There are boot loops and posters get stuck at the boot animation. Always backup your base ROM after a fresh install that you can restore back to when trying out different themes.
Landshark
4,434
1,382
113
Ha ha! Thanks for reminding me of one more thing I need to do Jaekar. I forgot when I put my testing off to the side I wanted to see if it was possible to fix permissions through adb while the phone was still in cwm since fix permissions is not working in cwm. That would hopefully alleviate the problem of restoring a nandroid.
JaeKar99
1,260
712
I have been fixing permissions via adb exclusively the past few days. I have not flashed a theme during that time though.. that will get done - when all the side projects die down.
fallingOutOfLoveWfithTech
