10-26-2013 05:34 AM
1,056 ... 40414243
tools
  1. JaeKar99's Avatar
    Hello. I installed MTD Vanilla Gingerbread v7 and I can't access Verizon backup assistant so I can restore my contacts. I did a titanium back up prior to the MTD Vanilla Gingerbread v7 installation, but I couldn't retrieve my contacts...please help.
    If you have sync'd your contacts with Google when you intitally set up your phone to sync contacts and gmail you should have contacts..
    I know that CM7 and the other mtd based ROMs do have that capability but not via backup assistant.
    There was also the option to export your contacts to your sd card - that is also an option?
    11-19-2011 08:12 AM
  2. Rigor Mortis's Avatar
    Thanks Jaekar99, you guys really know your stuff...BTW, Happy Thanks Giving to everybody!!!!!!!!!!!!!!!!!
    11-19-2011 12:55 PM
  3. Rigor Mortis's Avatar
    Hello. After installing MTD Vanilla GingerBread v8 I am having FC issues with gapps. I installed gapps update 2.3.5. Any ideas?
    11-21-2011 01:38 PM
  4. JaeKar99's Avatar
    I have not used VG but I know for the FC issues I have had on Pool Party it was related to not wiping data before flashing the ROM..
    11-22-2011 09:44 AM
  5. JaeKar99's Avatar
    As some of you know Megaupload.com was closed due to the Department of Justice /FBI - I was using that site for storage of many boot animations and other icons resources..
    Many links that were provided for the users on this side are now disabled.. For that I am sorry.
    01-19-2012 04:52 PM
  6. Maziah Zemerdon's Avatar
    is it me or are some of these links not working ? example, SuperClean 2.x - Electric Purple Honeycomb
    10-26-2013 05:34 AM
1,056 ... 40414243
