- 03-25-2011, 10:31 PM #101
- 03-25-2011, 10:35 PM #102
- 03-26-2011, 06:43 AM #103
- 03-26-2011, 06:59 AM #104
- 03-26-2011, 07:07 AM #105
ultimate honeycomb v 3.1
Currently running eb01/16 sc 2.9.1
Flashed ultimate honeycomb the other day. Absolutley love it. The only issue I have come across thus far is I can't get the keyboard to vibrate on key press. I have gone into keyboard and settings, made sure it was checked off. I even unchecked it, reboted then checked it again. Still nothing. Its really not a huge deal but I'm very used to the vibe on press options.
Any insight?Blackberry 8320? OLD > blackberry 8703e > blackberry curve > blackberry Storm 2 > Samsung Fascinate>Droid Charge - 03-26-2011, 08:00 AM #106
- 03-26-2011, 08:40 AM
Thread Author #107
This is the first I have heard of this happening. I have been looking at the posts in the developer's thread and have not encountered this specific to the theme causing this.
You should make certain that your vibration intensity is set also, Settings, Sound settings - > scroll all the way to the bottom Vibration intensity.. make certain it is set where you want it. There is also a haptic setting in spare parts. It is rare that it will cause issues but make certain that has a check also.
I will continue to look for possible conflicts in the theme's developer thread. Thus far no reports.Confucius: “Never use a cannon to kill a fly.” - Take off and nuke it from orbit.. ~~^^~~Thanked by: - 03-26-2011, 09:37 AM #108
- 03-26-2011, 09:50 AM
Thread Author #109
Confucius: “Never use a cannon to kill a fly.” - Take off and nuke it from orbit.. ~~^^~~ - 03-26-2011, 09:52 AM #110
- 03-26-2011, 10:05 AM
Thread Author #111
Confucius: “Never use a cannon to kill a fly.” - Take off and nuke it from orbit.. ~~^^~~ - 03-26-2011, 10:18 AM #112Shouldn't we treat this world like the Garden of Eden and avoid the apple at all costs?
Sometimes you go to the circus...........Sometimes the circus comes to you.
Instructions on how to flash ROMs, Kernels, Patches, and Mods through clockworkmod recovery, CWM: DroidXcon's CWM Thread
If you add me on Google+, please list your AC username as a nickname so I know who you are.Thanked by 2: - 03-27-2011, 03:25 PM #113
- 03-27-2011, 03:45 PM
Thread Author #114
Confucius: “Never use a cannon to kill a fly.” - Take off and nuke it from orbit.. ~~^^~~ - 03-27-2011, 04:03 PM #115Blackberry 8320? OLD > blackberry 8703e > blackberry curve > blackberry Storm 2 > Samsung Fascinate>Droid Charge
- 03-27-2011, 04:04 PM #116
- 03-27-2011, 04:04 PM #117
- 03-27-2011, 04:50 PM
Thread Author #118
Try this . I am not certain it will work with the Fascinate.
To install: Use method A on post #7 of this thread... If you cannot get it to install you will need to download the bootanimation.zip and install using method B on the same post.Confucius: “Never use a cannon to kill a fly.” - Take off and nuke it from orbit.. ~~^^~~ - 03-27-2011, 04:52 PM #119Shouldn't we treat this world like the Garden of Eden and avoid the apple at all costs?
If you add me on Google+, please list your AC username as a nickname so I know who you are. - 03-27-2011, 05:39 PM #120
- 03-27-2011, 05:55 PM
Thread Author #121
Confucius: “Never use a cannon to kill a fly.” - Take off and nuke it from orbit.. ~~^^~~ - 03-27-2011, 10:34 PM #122
- 03-27-2011, 11:04 PM #123
Nitrocomb does more and deeper theming than va green. You will need to wipe cache and dalvik and flash va green again. If that doesn't do it you will need to wipe cache and dalvik, flash sc 2.9.2v, reboot, boot back to cwm, wipe cache and dalvik, flash va green, then reboot.
If you add me on Google+, please list your AC username as a nickname so I know who you are. - 03-28-2011, 08:22 AM #124Blackberry 8320? OLD > blackberry 8703e > blackberry curve > blackberry Storm 2 > Samsung Fascinate>Droid Charge
- 03-28-2011, 09:13 AM #125
Needs some memory (mine) help. One of the many Roms/themes I've flashed lately had the shutdown boot that I liked the most but I can't remember which one and can't find it listed anywhere. Its the one that just shuts the screen down (like the old TVs) to the single horizontal line across the screen then gone......don't even know the name so that probably doesn't help. Anyone?
Reply
