on the va green thread on xda there is a zip for icon docks and wallpapers. it says to unzip and use as you please. what do you do with it once it is unziped?
What if I flash a theme and don't like it? How can I get my old theme back? I'm running EB01 SC 2.9.1.
JaeKar (or anyone else),
I extracted the 'bootanimation.zip' file from Adryn's SC 2.9 voodoo zip with the intention of copy/pasting it into the 'system > media' folder on my phone.
I renamed the current boot file in that folder to 'bootanimation.zip.old' then pasted Adryn's boot file.
After rebooting, instead of seeing that great exploding honeycomb animation, all I saw was the word 'ANDROID' on the screen in landscape view with some highlighting animation... not what I expected!
Was I supposed to flash Adryn's bootanimation.zip with CWM or did I do something else wrong? DroidXcon seemed to think it has something to do with VooDoo and said to ask you or Gunnermike...
Thanks for any guidance!
- Vince
Hello, wast told talk Jaekar about how to go about getting sound for the bootanimation.zip currently running EC10SC292x_DXc.tar.
The bootanimation displays and works fine except for the sound part of it.
What can I do to fix it. All files are in the proper places
are any of these themes capabile with the ec10 kernel?
i have va green on 2.9.2 and i just noticed that in the notification bar it still says 2.9.1.
I just flashed Nitrohoneycomb and I'm liking it so far except I'm not a big fan of the way the keyboard looks...Is there any way I can change that back to the stock SC 2.9.2 keyboard?
Also, If i wanted to go back to stock SC 2.9.2 with no theme, what would be the best way to do that?
To get back to stock - You should restore your nandroid back up of the ROM before you flashed your theme... it is recommended (strongly) that you do a back up of your ROM prior to flashing your theme of choice.
Worst case scenario is to clear caches (Dalvik and partition) then reflash 2.9.2. That will take you back to stock without any loss of data.
Hey JaeKar...I tried a nandriod restore earlier today, but ended up in a boot loop. When I asked about it, gunnermike informed me that restore in CWM is broken and is being fixed. I am assuming there is no other way to restore your nandriod back-up excpet through CWM, is that correct?
