Jmac9
ok all you beautiful minds out there i have mad 2 nandroids and i would like to restore 1 to see that it restores properly jsut to make sure i have my "save point" in the fascinate game for when i get to the harder levels haha so am i needing to do anything special before restoring a nandroid clear or wipe anything ? and if it happens to get jacked up am i just doing a batt pull and going to hook up via usb to yellow dl triangle to fix or ? i wanna know all my options first and im having a fun time trying to find the info i am looking for and if there is just a link to a read all thread for the restore im glad to read just needing help thanks to all u genius fascinate minds
Couple of things.....
Where are you with CWM......did you install the latest fix? If so , then you should be all set to do backups and restore. I personally wipe cache and Dalvik unless otherwise instructed by dev. No need to wipe data.....doesn't make sense to do that if you are backing up your data does it? If you are not sure of where you are on the CWM (broken or not) then I suggest you go through this thread and follow intsructions needed......
http://forum.androidcentral.com/ver...od-superclean-roms-erasing-cwm-confusion.html
