Flashed phone with froyo and theme and backed everything up with titanium backup and wiped cache as advised now I realized im missing my music player app/widget and also the alarm clock when set is not setting for the correct day. thanks in advance
Thanks but I was pretty sure I dont have super clean
How did you flash froyo? If you used DXC's odin packages your probably on super clean. You can always pull down your notification shade and it'll say on there if you're on super clean. If not, then I'm baffled. REFLASH!
I used the post you created, flash for beginners.
ok i did a system recovery and all is well except for now i need to reinstall my theme, no big deal but my stock calender is mia and when i try to set and alarm for the following day it says its set for 5 days and etc.im lost help i need my alarm thanks
The alarm is a known bug. I've never gotten that one figured out. The theme could be messing with your apps like the calendar. You can always delete the one in the system/app folder, and move the original .apk file there with root explorer or something of that nature.
Just finished flashing 2.9.2, trying to reinstall everything I saved with My Backup, do I install all or do them one by one?
I don't get it, I just don't get it. I was helping you in another thread, and now that you've flashed 2.9.2, you post a new follow up question in a completely different thread. I think I am just about done with these forums.
Sorry Shark don't get mad. I was just trying to get my question answered, may have to start my own thread for some of the questions I have now that I flashed froyo (2.9.2) My apologies!
