Bfascinated
Thats a great suggestion and thanks! Makes sense to have a set up that you know will work with your phone to be your boot set up just in case. That allows you to tweak knowing that if you have to reboot, you'll be ok.
You're welcome, just trying to help! I just happened to luck out with my first settings, I was using the comavolt before, I thought I read somewhere that was -100, so I tried that for the big ones, and stepped it up a little for the lower ones and it works great, now I'm going to see if I can be a little more aggressive!
