1. dgh1's Avatar
    Hello, I was trying to return to stock using this link:
    http://forum.androidcentral.com/veri...yo-update.html
    Now my phone is "Soft bricked" and looks like the picture in post #7 in the link above.
    Odin does not get past initialization step.
    I have tried to re-download the .tar file, disabled anti-virus, and I am using a strong USB port. Also tried alt factory data reset, and boot into recovery.
    Any help would really be appreciated. Thank you.
    Attached Thumbnails Stuck on "soft brick" screen-samsung_galaxy_s_black_screen_of_death.jpg
    05-06-2011 02:56 PM
  2. Lttlwing16's Avatar
    http://forum.androidcentral.com/veri...ed-3-25-a.html
    Post #4 has what you need.
    dgh1 likes this.
    05-06-2011 04:54 PM
  3. dgh1's Avatar
    Thank you Littlwing16, that link says to re-download Odin, that's one thing I have not tried that yet. I'm at work for the night, but will try it in morning.
    05-06-2011 05:11 PM
  4. DroidXcon's Avatar
    If none of that works find me and ill help you out
    dgh1 likes this.
    05-06-2011 05:12 PM
  5. dgh1's Avatar
    Thanks DroidXcon
    05-06-2011 05:51 PM
  6. dgh1's Avatar
    I'm all set, followed the exact instructions from the link Lttlwing16 gave me, turns out I was not extracting the file before trying to load with Odin. Guess it pays to slow down and actually read everything, haha. Thank you again.
    05-07-2011 12:00 PM
  7. Lttlwing16's Avatar
    Hey, glad you got it worked out!! Droid X Con is pretty much the man. His threads pretty much cover it all.
    I feel your pain...this stuff is exciting.. but I can't count how many times, I just "moved forward" and overlooked something.. wishing I had taken just a couple minutes to re-read something!
    Have fun! and enjoy!
    05-07-2011 02:03 PM
  8. jean001's Avatar
    I have to reread stuff a few times because I tend to read fast and skip lines.
    05-07-2011 04:11 PM
