Okay, I'm on KBCR v1.3 (voodoo) with the OTB 1.4 Kernel that came with it.
Voltage Settings:
Scheduler: sio
Limit Clock to: 1200 Mhz
1200 Mhz: 1300-0=1300mV (-0)
1120 Mhz: 1300-0=1300mV (-0)
1000 Mhz: 1275-50=1225mV (-50)
800 Mhz: 1200-50=1150mV (-50)
400 Mhz: 1050-75=975mV (-75)
200 Mhz: 950-75=875mV (-75)
100 Mhz: 950-75=875mV (-75)
I always keep it at the lowest brightness when not in use, and anytime I'm not out and about, I have it on the charger. Perhaps I have a wimpy battery?
I downloaded CPU Spy the other day, and my phone likes to stay on 100MHz 61% of the time, so I figured I could undervolt it to -100mV, but my phone crashes at that setting. I even tried using SetCPU to make a screen-off profile to where it uses the bare minimum of CPU while it's just chilling there. But it just ends up crashing my phone too. I even try clearing Battery Stats and everything and do the whole procedure. But still, no such luck...Is it time I buy a new battery?
When I flashed to the Comm ROM the first time, I was on SC 2.9.2 with EC01. I'm starting to think I should flash all the way back to stock and start from scratch and get all the way back up to KBCR 1.3. Skipping the SC2.9.2 part, of course. I want to go straight from the ED01 Build, perhaps the ED03 build. Whichever one I get first.
Right now, this is my phone's info:
Hardware Version
I500.04
Model Number
SCH-I500
Firmware Version
2.2.1
Baseband Version
S:I500.04 V.EB01
Kernel Version
2.6.32.9
Build Number
SCH-I500.ED01
The Baseband and Build Number are the parts that confuse me. SHouldn't I have something other than EB01 as my Baseband??
So, my questions are:
What do I need to do fix my battery?
What's up with my phone's info?
ANY advice would be much appreciated. Thanks so much, guys.
Voltage Settings:
Scheduler: sio
Hardware Version
I500.04
Model Number
SCH-I500
Firmware Version
2.2.1
Baseband Version
S:I500.04 V.EB01
Kernel Version
2.6.32.9
Build Number
SCH-I500.ED01
