Results 1 to 10 of 10
    Default Sound not working
    My roommates fascinates sound stopped working. No matter what sound is set to it don't work on phone or apps.
    Its running ed01 debinged debloated rom for months now without problems till yesterday.
    I tried reflashing the rom, pulling the battery, flashing commrom and still nothing. Also when flashing commrom I had to activate voodoo and I didn't hear the lovely lady...Please help
    Sent from my SCH-I500 using Tapatalk
  2. #2
    JaeKar99's Avatar
    Posts
    ROM
    ICS 4.0.4 build 8
    Default
    If you have done all that it may be hardware related.
    Edit: You could flash back to stock and see if that gets you some results.. if not.. consider a replacement.
    Confucius: “Never use a cannon to kill a fly.” - Take off and nuke it from orbit.. ~~^^~~
    Default
    I really think its a hardware issue since i didn't even hear the voice when activating voodoo. He got the phone at BestBuy, would he take it back there or to verizon? On the samsung website it says its still under warranty so a hardware issue should be covered..?
  4. #4
    wyllic's Avatar
    Posts
    ROM
    Eclipse 1.3 / PBJ non-oc
    Default
    If he bought it at best buy and pays for their equipment protection, then by all means take it there! They'll open a box and hand him a brand new phone, whereas verizon will give you a refurb
    If you're going to be crazy, you have to get paid for it or else you're going to be locked up.
    -- Hunter S. Thompson
    Default
    He didn't buy there equiptment protection. Would they give him a refurb also?
  6. #6
    curley's Avatar
    Posts
    Global Posts
    461 Global Posts
    ROM
    AOKP Devil 40.1
    Default
    Quote Originally Posted by Nytom30 View Post
    When you hit your media Volume, does it read, BLUETOOTH VOLUME? Run Pandora or something like that.
    I had this happen. I played music through BT and it got stuck. Make sure your BT is turned off and reboot the phone. It should start to work again, if this is your issue.
    I know enough to get into trouble, but not enough to get myself out of that trouble.
  7. #7
    wyllic's Avatar
    Posts
    ROM
    Default
    If he didn't buy their equipment protection then he has to go into Verizon
  8. Thread Author  Thread Author    #8
    Default
    Well I flashed it back to stock and removed all traces of rooting and flashing and it still don't work. Looks like we'll be going to verizon tomorrow.
  9. #9
    icu
    icu is offline
    icu's Avatar
    Posts
    ROM
    CM 10.1
    Default Re: Sound not working
    Yeah - I was about to ask if they've tried plugging in a headset or speakers.
  10. #10
    If anyone else runs into this, sometimes the phone starts sending invalid signals that a headphone in plugged into the jack, when it is not. This causes the speaker and earpiece to no longer function.
    There is an app named SoundAbout that was originally written to alleviate this issue. It also does some other nice audio routing as well. The pro version allows routing of Bluetooth and also also special routing for phone calls.
