I recently tried out the GB leak for my fascinate. Currently, everything is stock rooted and personally debinged. Can I use Nemesis2all's kernel for the cm7/miui? It has listed 2.6.35 0620 as the kernel version and the EC09 GB leak uses 2.6.35.7. I was thinking that the GB kernels were different, but since this kernel is using the 35 base, I should be able to use it, am I right? Just looking to get some feed back and see if it makes a difference as I miss voodoo. Just looking to see if I am right in my thinking or not. Thanks!
