My sd card is showing up damaged in the notifications bar. If I click on it it asks me if I want to format. But it only says "sd card is currently being checked" when I try
When I go to storage in the settings menu and try to mount it ""sd card safe to remove" shows up in my notifications bar followed by "Damaged sd card" again
I've tried going into recovery mode to wipe data, factory reset, and I tried to partition the sd card, just to see if it would work. For some reason the sd card isn't mounting.
I also tried hooking it up to my windows computer to format it, but it wouldn't show up. When I tried the same thing in a digital camera it said "corrupted sd card"
it's the original 16gb card that came with my fascinate, not even a year old yet. Anyone have any ideas?
