Results 1 to 3 of 3
    Loudestbough's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    SC3 Milestone 2
    Default Wife's Fascinate is crushed... Help transferring to a DroidX???
    Literally, my wife's phone is crushed. Our neighbor gave her a droidx that whe wasnt using, but I need to get her droid set up like her fascinate. I had it rooted (2.2 GeeWiz), with Titanium Backup. If I root the droid, can I reinstall everything through titanium backup, or is it a lost cause? Can someone give me some info on this please?
    Thank you in advance.
  2. #2
    anon268366's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP Build 33
    Default
    If you backed up the apps data then it is saved in the sd card. So if that is still in tact you could get the data off of it. Or just put the sd card in the Droid x. Personally I would just redownload all the apps and such, and just restore the apps data on the Droid x. Hopefully this helps or gets you on the right tract.
    Sent from my SCH-I500 using Tapatalk 2
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    SC3 Milestone 2
    Default Re: Wife's Fascinate is crushed... Help transferring to a DroidX
    Yea, I have her SD. How do I reinstall from the SD? I am worried that if I redownload the apps, it will replace the files and she will lose her saved data.
