1. Loudestbough's Avatar
    Literally, my wife's phone is crushed. Our neighbor gave her a droidx that whe wasnt using, but I need to get her droid set up like her fascinate. I had it rooted (2.2 GeeWiz), with Titanium Backup. If I root the droid, can I reinstall everything through titanium backup, or is it a lost cause? Can someone give me some info on this please?
    Thank you in advance.
    04-24-2012 08:11 PM
  2. anon268366's Avatar
    If you backed up the apps data then it is saved in the sd card. So if that is still in tact you could get the data off of it. Or just put the sd card in the Droid x. Personally I would just redownload all the apps and such, and just restore the apps data on the Droid x. Hopefully this helps or gets you on the right tract.
    Sent from my SCH-I500 using Tapatalk 2
    04-24-2012 08:27 PM
  3. Loudestbough's Avatar
    Yea, I have her SD. How do I reinstall from the SD? I am worried that if I redownload the apps, it will replace the files and she will lose her saved data.
    04-25-2012 09:38 AM
