1. zrxoa1's Avatar
    Trying to get maps working on her fascinate. Every time she hits navigate, it sends her to vz navigator. Did google do away with its own navigation ?
    Sent from my iPhone 5 using Tapatalk
    09-29-2012 07:01 PM
  2. Irvgotti's Avatar
    Maybe VZW got set by default. This might work.. OK go into settings.... click the apps tab... once you are in there. You should see Downloaded , running or all, Scroll over (swipe over) to the All tap. Locate VZW navigator... click it and clear defaults. Now try again. Should ask you which navigation you want to use, it happend on my old phone.
    09-29-2012 11:11 PM
  3. zrxoa1's Avatar
    Yep, that was it. Thank you very much! I never had that happen on my Incredible or Rezound. Her Fascinate is awfully buggy, time to upgrade her to a shiny, new Galaxy S III I think. :-)
    Irvgotti likes this.
    09-30-2012 12:09 AM
  1. Possible spyware apps on my wife's phone. Help!!
    By Bond111 in forum Droid Bionic
    Last Post: 07-06-2012, 03:25 PM
  2. need help on my cellphone gallery
    By Cluna99 in forum General Help and How To
    Last Post: 01-21-2012, 08:12 PM
  3. Need major help with my Fascinate!
    By cmarie81585 in forum Verizon Fascinate
    Last Post: 03-02-2011, 11:19 PM
  4. do i need MR2 update on my eris
    By borgey401 in forum HTC Droid Eris
    Last Post: 03-31-2010, 03:02 PM
  5. Need help on my rooted my touch 3g hero rom
    By VoLoDaR1 in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 12-17-2009, 08:34 AM
