Results 1 to 3 of 3
    markteggert's Avatar
    Junior Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default i need help with my galaxy fascinate.
    i have a galaxy fascinate. it was locked when i got it so my wife reset the phone. now it has some sort of activation screen. the problem is, is that i dont have verizon, i am with boost. How do i get out of the activation screen? And after that how do I switch my phone to boost mobile? Isd there someone out there that can help me? If so can you plllllllleeeeeeeaaaaaaasssse email me or call me and help me cuz im really illiterate when it comes to phones and computers. PLEASE HELP ME. thank you.
  2. #2
    Xopher's Avatar
    Posts
    Global Posts
    4,732 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    All Stock
    Default Re: i need help with my galaxy fascinate.
    You are going to find it to be very difficult to get the phone switched over. I'm not sure if Boost Mobile is a CDMA or GSM network carrier. If they are CDMA, you'll have to flash the phone with their network settings (possibly check rootzwiki.com). After that, you'll have to convince Boost Mobile to add the phone to their network. CDMA registration is done by the carrier (GSM networks just need to insert a SIM).
    If Boost Mobile is a GSM based network, it won't work. Both networks use completely different radios.
  3. #3
    NGEFreek's Avatar
    Posts
    Global Posts
    684 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Gingerbread
    Boost mobile is indeed a CDMA carrier, but I doubt you'll be able to successfully flash over and activate onto their network with a fascinate.
    Sent from my 4.1.2 Deviled Unicorn I500
  1. I need help with my g1!!!!
    By extremefire2 in forum HTC G1/Dream Rooting, ROMs, and Hacks
    Last Post: 05-01-2011, 09:54 AM
  2. I need help with my PRI
    By thetony2313 in forum HTC EVO 4G
    Last Post: 08-31-2010, 04:34 PM
  3. need help with my phonelist.
    By zeiferx in forum Verizon Droid Incredible
    Last Post: 06-06-2010, 01:16 AM
  4. I need help with my software
    By naenaek22 in forum HTC Droid Eris
    Last Post: 05-25-2010, 01:54 PM
  5. Need help with my rooted mytouch3g running hero rom
    By VoLoDaR1 in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 12-16-2009, 06:52 PM
