Results 1 to 6 of 6
- 09-11-2010, 06:40 PM
Thread Author #1
Battery Increments?
Does anyone know how to look at how many percent your battery is at? and also to show it on the notification bar?
1 more question, where was that thread that showed you how to put a led notification on your screen? - 09-11-2010, 06:49 PM #2
To see the battery percentage, go to Menu / Settings / Battery Manager.
If you want the percentage to be shown in the notification bar, you can get Gauge Battery Widget free from the Market. - 09-11-2010, 06:52 PM #3
Re: Battery Increments?
I use Battle Statt
-Made using my Android Phone - 09-11-2010, 06:53 PM
Thread Author #4
there is no battery manager...
- 09-11-2010, 06:56 PM #5
- 09-11-2010, 07:01 PM #6
Download and use Battery Droid. It's got a widget you can put on your home screen with the percentage left. Works great.
Reply
