Results 1 to 25 of 41
- 09-12-2010, 12:07 AM
Thread Author #1
Removing the "permanent" Verizon Bookmarks - Easy Solution
After playing around with the LauncherPro bookmark widget (which I love!), I was getting pretty annoyed having to look at some of those default bookmarks (MSN.. really?).. So you open up browser, do the long-click on the bookmark, scroll down to delete, and bye-bye bookmark!
Except.. Verizon can be a jackass, and set their own bookmarks to permanent. So halfway into working with the browser's sqlite database file, I ran across an easy solution. I wish I had the original link to give credit, but I can't find it anymore. If I do, I'll come back and edit with the original link..
1 - Open up Browser
2 - Go to Bookmarks
3 - Use one of the Verizon bookmarks to load that page. Let the page load.
4 - Go back to bookmarks, click on history tab.
5 - See the yellow star next to the Verizon web page you went to? Touch the yellow star to deselect it.
Stupid VZW bookmark goes bye-bye.
Thanked by 27:+ Show/Hide list of the thanked
- 09-12-2010, 01:13 AM #2
Ahh what a simple fix. Thank you, those were driving me crazy.
- 09-12-2010, 07:58 AM #3
great tip !! Thanks. worked like a charm.
- 09-12-2010, 08:13 AM #4
- 09-12-2010, 08:16 AM #5
Such a simple fix for such an annoying Big Red push. Thanks a bunch!
- 09-12-2010, 08:50 AM #6
- 09-12-2010, 08:52 AM
Thread Author #7
- 09-12-2010, 08:53 AM #8
Re: Removing the "permanent" Verizon Bookmarks - Easy Solution
Thanks for the fix!
Sent from my DROIDX using Tapatalk - 09-12-2010, 09:00 AM #9
Very nice. Thanks for sharing.
- 09-12-2010, 10:04 AM #10
- 09-12-2010, 10:08 AM
Thread Author #11
It was my understanding the yellow star indicated there was a bookmark for that page. Perhaps what's in your history is a different page than what you have bookmarked? For example zzz.com/1234 is bookmarked, but the page in your history is zzz.com/5678 ?
If that's not it, then it beats the heck out of me. - 09-12-2010, 12:04 PM #12
Awesome fix. I spent several hours trying to figure that one out on the Droid X, before I finally gave up.
- 09-12-2010, 01:07 PM #13
- 09-14-2010, 04:20 PM #14
- 09-14-2010, 04:55 PM #15
- 09-14-2010, 04:58 PM #16
great find!
- 09-14-2010, 04:59 PM #17
Have you edited your homepage yet? I did that, and the VZW link disappeared. Open browser, hit menu button, select More, select Settings, scroll down to "Set home page"
- 09-14-2010, 05:54 PM #18
- 09-14-2010, 06:52 PM #19
- 10-05-2010, 03:35 PM #20
Awesome! Thanks so much!
- 10-05-2010, 06:41 PM #21
Awesome! I'm sure Verizon will consider this a bug
- 10-05-2010, 06:49 PM #22
- 10-05-2010, 10:32 PM #23
- 10-06-2010, 11:05 AM #24
This is a great tip. I added this to the Getting Started with Android - Tips and Tricks under Internet Tips and Tricks:
• Delete undeletable bookmarks: Tap Menu > Bookmarks > {bookmark} > Menu > More > History >tap the yellow star.— Milo
← Tap Getting Started at the top of any page for help with:
- Settings - Email - Backup Everything - Phone - Messaging - Music & Photo Sync
- Keyboards — Folders - Favorite Apps - Extending Battery Life - My Avatar
- iPhone User's Guide to Android - (Palm) - Tablet & Phone Comparison - Epic4GT - ATT - TM
If this helped, please click ↓Thanks & Like↓ - 10-06-2010, 02:03 PM #25
Reply
