Results 1 to 13 of 13
    Default Speak Incoming Caller ID + Ringtone?
    Is there a setting to get the phone to read the incoming caller ID, and then play the ringtone? The only option I can find is on or off, and when set to on, it just repeats the caller ID over and over.
    Thank You
  2. #2
    saymes's Avatar
    Posts
    Global Posts
    39 Global Posts
    Default
    Hey mikey6p. Where did you find that opton? I'm looking for something like that.
  3. #3
    Default
    saymes, it's under settings, then text-to-speech
    Thanked by:
  4. #4
    saymes's Avatar
    Posts
    Global Posts
    39 Global Posts
    Default
    I've been there. I don't have anything about speaking the Caller ID. What OS are you on? I'm on 2.2. Unless it is a carrier-specific feature.
  5. #5
    Default
    Might be carrier specific. my vzw fascinate has it...running 2.1 dj05
  6. #6
    davidnc's Avatar
    Posts
    Global Posts
    5,627 Global Posts
    ROM
    Nexus(AOKP-jb_4.2.1)
    Default
    mine shows that option on dx under:
    menu>settings>call settings>other call settings and there you have 3 options....ring only...caller id then ring..caller id repeat.
    sent using TaPaTaLk
    SGSIII : White 32 gb model with 32 gb sdcard
    RoM : CleanRom 5.5.1_ jb
    Kernel : n/a
  7. #7
    Default
    Quote Originally Posted by mikey6p View Post
    Thank You
    I"m looking for the same thing for my Galaxy S. ...speak the caller ID once, then go to ringtone.
  8. #8
    gunnermike53's Avatar
    Posts
    ROM
    Gummy, AOKP
    Default
    voice in put out put. install speech synthesis
  9. #9
    Default
    Quote Originally Posted by gunnermike53 View Post
    My Galaxy S has voice to speech and it works well. I can set it to announce the Caller ID or set to a ringtone. I want it to both. My previous phone could be set so that it would announce the callers name/number, then start the ringtone.
  10. #10
    esrakes24's Avatar
    Posts
    ROM
    SC 2.9.2 ComaVolt
    Default
    Doesnt Vlingo have a caller id speech option?
  11. #11
    Posts
    ROM
    Gummy, AOKP
    Default
    Quote Originally Posted by esrakes24 View Post
    it does.
    the other thing i said doesnt work.
  12. #12
    Default Re: Speak Incoming Caller ID + Ringtone?
    Dear Sir,
    Please ask how to download say callers name software in my nokia 6300?
    chinmoy
  13. #13
    Dragon will do that, you can also set it to read the text if you want. It does very well at names. It is free in the play store.
    Sent from the AWESOME Note 2 of a girl
    Thanked by:
