Fascinate not recognizing USB mode
katvo
Active member
Nov 9, 2010
27
Hello,
I'm having an issue getting a Fascinate to connect to my computer. I updated the Fascinate drivers, but the Fascinate isn't recognizing the Mass Storage mode. It's only charging, no other options.
How can I get it to recognize Mass Storage mode? There is no notification in the bar that it's even connected? I'm googling myself crazy over here and I can't find anything!
Thanks
DroidXcon
11,102
3,392
Hello,
Thanks
ok first go to settings>USB settings> select Mass storage.
then go to settings>Applications>Development>USB debugging.
then connect fasinate, it will now auto set up the drivers.
once its done doing its thing, disconnect the USB,
go back and disable Debugging, then reconnect and you should be ok
hope that helps
katvo
Active member
Nov 9, 2010
27
That's the problem... It's not giving me that option. When I plug it in, the only thing it does is charge. It's not giving me an option to mount the sd in the notification window.
Is there another way to get to that option?
My computer isn't recognizing the Fascinate either. And I just re-updated the drivers from Samsung's website. :/ I'm really stuck here. I must be missing something.
DroidXcon
11,102
3,392
Im really sorry but i have to ask you some of this basic stuff, have you tried different USB ports, sometimes they assign themselves, other times they time out,,,etc
katvo
Active member
Nov 9, 2010
27
haha, it's quite alright. I've tried all my USB ports. And like I just said, I just plugged in my Ally and my Incredible and they worked just fine.
DroidXcon
11,102
3,392
ok did you try removing your SD, card and connecting it without it onboard,,,i know that sounds kinda of nonsense,,,,, also check your device manager on your computer see if it gives you any flags,,, try install wizard,,,, and if all this doesnt work maybe we need to install SDK adb drivers
Sta11i0n
958
151
So are you saying that when you connect the USB, and pull down your notification window, it doesn't say USB connected? Or when you click on that it doesn't give you the pop-up to mount?
guylenn49
