Quote:
Originally Posted by dgriff945 i tried to mount my phone when i have usb debugging turned on and that still doesnt work. it should be such an easy thing to do but its turned into hours of frustration. does anyone know what to do????
oh i even wasted 5 bucks on tunesync to try to wirelessly sync my music but that obviously didnt work either. | I assume you tried it with USB debugging off too?
Have you tried a different port on your Mac?
Have you tried rebooting your Mac with your phone plugged in? Some people have reported it mounting properly when they did this.
Personally, I save myself the trouble of transferring over USB & plug the SD card in via an SD card reader.
Are you running the latest update? If so, there's a whole thread about this where people are having issues.
When you do get this fixed, you should try iSyncr. Much better program.
