1. fstbusa's Avatar
    I did this Nav Volume fix when running DI01 stock ROM/Kernel and it worked great.
    Navigation Volume Low - Droid Forum - Verizon Droid & the Motorola Droid Forum
    Recently I've flashed to DJ05 and am running a superclean rom with stupid fast kernel.
    I can't seem to get the settings to stick. I fill them out accordingly and hit "save" and exit out and go back into the menu and it is set back to stock.
    Is is possible these values are set by the ROM or Kernel and I can't change them?
    Thanks for any insight.
    01-14-2011 05:38 PM
  2. CeDj's Avatar
    I noticed the exact same thing and just thought I was screwing up the save somehow. I'm running the SuperDark DJ05 ROM with JT's 12/30 kernel and I could not get the settings to save. It worked fine when I was on the DI01 SuperClean ROM.
    01-14-2011 05:45 PM
  3. jerkules's Avatar
    What you need to do is now is flash back to a di01 kernel (only), make the changes, then flash back to the dj05 kernel. After that, you should be set. The settings will stick.
    CeDj likes this.
    01-15-2011 10:05 AM
  4. Chris Kerrigan's Avatar
    +1, that seems to have been the fix for this issue.
    01-15-2011 11:29 AM
  5. fstbusa's Avatar
    anyone have a direct link to the DI01 kernel?
    I've found the whole md5 file but I can't seem to find just the kernel.
    01-16-2011 08:43 AM
  6. French's Avatar
    I find it unacceptable that this is even necessary and now that I've done the OTA update I'm VERY ticked off that I now (again) have useless navigation.
    I've seriously had it with the issues with this phone. I really want to love it but things don't work as they should. Seriously...navigation volume so low you can't use it in a car, and Samsung hasn't even acknowledged it as an issue, let alone tried to fix it.
    01-16-2011 10:17 AM
  7. CeDj's Avatar
    Thanks Jercules. It worked when I flashed the kernel back to StupidFast 1.23 (DI01), changed the system settings, then flased the kernel back to JT's 12/30 kernel (DJ05). What's the reason that this works with the DI01 kernels and not the DJ05 kernels? Will I have to do this all over again if I update to the new DL09 package that Adrynalyne put out?
    01-16-2011 04:03 PM
  8. fstbusa's Avatar
    I'll give this a shot and see what happens.
    01-16-2011 08:01 PM
  9. afbar1114's Avatar
    props to the guys over at droid forums(not sure if we allowed to post this) but it shows how to fix your gps voulme and it WORKED!!
    Facinate G nav volume too low - Droid Forum - Verizon Droid & the Motorola Droid Forum
    Edit: NVM doesnt keep but maybe someone can work on it and try another hopefully this will help someone or us
    01-18-2011 10:45 PM
  10. wtherrell's Avatar
    Hmm. I applied the fix while still in DI01. I skipped DJ05. When I did the OTA to DL09 the fix was still there and Nav volume is still just fine.
    01-21-2011 10:45 AM
  11. French's Avatar
    Interesting because I also applied the fix while still in DI01, skipped DJ05 and did the OTA to DL09, however my volume is not loud enough.
    01-21-2011 01:42 PM
