Hello all -
I've recently bought a new 2011 Jeep Grand Cherokee, which finally has support for Bluetooth Audio streaming, "from supported devices".
I have the fascinate, and I'm unable to get proper audio streaming to the vehicle. What do I mean? I can pair, and it can start the audio streaming (and it starts the default music player on device), BUT, the audio in the video sounds as if it's in fast-forward mode.. it plays this fast-music for a few seconds, then goes silent, then another few seconds of fast fwd.. continuously.
I've got access to a Droid 2 as well as a HTC Incredible, and only the Droid 2 provides reliable audio streaming to the vehicle. Both my fascinate and the incredible show the same symptoms of the fastaudio/silence.
Now, I'm entirely blaming this on the vehicle.. but, I figured I'd see if any of you have seen similar symptoms with other devices... were there any tricks to get it working?
I've was on thatdudebutch's DJ05 at first.. I then updated the Kernel a few times to see if that would change the success.. no luck.
I've now loaded the DL09 stock VzW on the phone and it too has the same symptoms..
At this point I've pretty much resigned to just sticking with an AuxAudio cable for now, and then upgrading to one of the 4G phones this year which would hopefully fix this feature.
I'll also be driving into the Jeep dealership this week to ensure that the MediaCenter is fully updated.
Thanks to anyone that has thoughts or ideas for things to try.
