Long story, but I bought a used Fascinate without the stock charger.
Could someone install, or hopefully already have, the "Battery monitor Widget". Then plug their Fascinate into the stock AC charger or stock car charger (NOT the USB on a PC), and let me know what the usage (ma) reading is on the widget.
More of the story. Basically, I know that at least on older HTC devices they would pull more charge/operating power from a non-USB connection. Actual USB is limited to 500ma load, so they had a system that kept the current low on USB and bumped it up for non-USB. All of the non-stock cables that I have show a very low charge rate on the Fascinate. It in fact runs the battery dead while on charge and I use the phone with GPS software.
