1. esrakes24's Avatar
    I'm using SkullCandy Hesh Shattered Gray Headphones and the volume on the media player is just not loud at all, Atleast for airplane use. I'm using Mvideo player. is there a different app that will make the volume much louder for use on an airplane? I'm rooted and on SC 2.8 this is for movies not music, The music is plenty loud it's just the movies
    03-10-2011 10:48 AM
  2. Sta11i0n's Avatar
    What format are the movies in/what audio encoding do they have? If it's in a 5.1 format like DD or DTS you're going to be missing a lot with just stereo headphones.
    03-10-2011 11:29 AM
  3. esrakes24's Avatar
    they are .avi under properties it says Audio- bitrate 192kbps
    03-10-2011 11:53 AM
  4. Sta11i0n's Avatar
    How many channels? Windows will tell you in the Details tab in the properties.
    03-10-2011 12:21 PM
  5. esrakes24's Avatar
    It doesn't say anything about channels anywhere in there, only thing under audio is what i posted above
    03-10-2011 01:28 PM
  6. Sta11i0n's Avatar
    Odd. It usually shows more like in my 2 examples.
    03-11-2011 12:36 PM
  7. Heath276's Avatar
    Hey just asking how do u put movies on your phone? Do u have to pay for them?
    Sent from my SCH-I500 using Tapatalk
    03-11-2011 01:30 PM
  8. Sta11i0n's Avatar
    The way we're doing them here is just by copying video files from your PC to your phone's SD card. Most of my movies, I own the DVD or Blue Ray and have just ripped them onto my PC in avi (divx) format. I have a NAS connected to my network which allows certain devices in my home (PS3 and 2 wireless blue ray players) to connect to it wirelessly and play from there like a media server.
    03-12-2011 10:23 AM
  9. mikethemedic's Avatar
    I know when i flashed superclean 2.9 the phone is much louder in general. Ringtone, music player, etc etc
    03-12-2011 10:44 AM
