guffster
This Froyo upgrade was a bit painful - Lost all my Launcher Pro widgets, and kept continually getting the "com.google.process.gapps has stopped unexpectedly" force close.
Was easily able to get the Launcher Pro widgets back by manually adding them again.
Finally corrected the "com.google.process.gapps" problem by going to System - Settings - Applications - Manage Applications - "All" tab - scrolled to "Gmail" app - performed a "Clear data" - then rebooted phone. I believe I also turned off all synching before-hand and then re-enabled it after the reboot.
Had several problems getting to the Market to try to get updates like Flash 10.2, and the newer Google Search (widget). Finally, after a few reboots, this magically(?) fixed itself and I could get to the Market again.
My one known problem now is the Camera app will not work. I get a blue dialog displayed over the Camera software stating "Please wait..." - and nothing works - it eventually times out and returns to Launcher Pro.
Anyone else seeing this "Please wait..." message with Camera app?
[RESOLUTION]
Fixed by performing: Settings - Privacy - Factory data reset - Reset phone. And then adding everything back again - What a PITA.
But camera app and everything else (so far) is working rather nicely now...
[RESOLUTION]
