Page 1 of 3 123 LastLast
Results 1 to 25 of 64
    OB1J3D1's Avatar
    Posts
    Global Posts
    29 Global Posts
    Default 2.2 = Horrible battery life
    All,
    since 2.2 I'm getting HORRIBLE battery life. First day I was playing around with it looking for all the new 2.2 goodness.
    But, today is normal usage.
    I normally get almost 24 hours out of a charge. I'm in the yellow now after 9 hours.
    Anyone else?
  2. #2
    TSX05's Avatar
    Posts
    Global Posts
    200 Global Posts
    Carrier
    both stock
    Default
    yeah my battery life is taken a major nose dive.
    used to be able to take it off charger 5:45am and still have battery at 10pm, not anymore, last two days after update have had to charge it at least once a day, WTH!!!!
  3. #3
    Landshark's Avatar
    Posts
    Carrier
    Infinity & Pool Party
    Default
    Quote Originally Posted by OB1J3D1 View Post
    All,
    Anyone else?
    Make sure GPS and wifi are turned off when you are not using them. They have turned out to be major battery hogs on Froyo.
    TheANARCHY likes this.
  4. #4
    Default
    All,
    Anyone else?
    I just helped someone with the same issue earlier, there's a thread that can help you out...
    I am having extremely good battery life personally. (I'm currently on stock ED01 updated via OTA.) There's a thread to help you try and sync your battery for better battery life, I'd give it a try and see if it helps. It worked great for me, my phone lasts over 24 hours with average use without going below 30% battery. Here's the thread: http://forum.androidcentral.com/veri...tery-life.html
    Edit: Don't worry about the terminal emulator part if you're not rooted (completely stock) Just do the charging part at the beginning. Charge to 100%, turn off let it charge to 100% while powered off, then turn back on and let it charge back to 100%. I recommend the part about draining your battery down to 2-4% after you have charged to 100% then recharging to 100% once more as this will sync your battery with your phone. Like I said it worked great for me and my battery life is amazing! Just be sure to read the information in the link to better understand the procedure.
    Good luck!
  5. #5
    Landshark's Avatar
    Posts
    Carrier
    Default
    Quote Originally Posted by FearTheGhost13 View Post
    Good luck!
    You're welcome everyone. And the part that is missing is step 4b after charging to a full 100%, run it down to about 5% with normal uninterrupted usage, then charge uninterrupted while on to 100%. That part does not actually sync the battery with the phone. It is the wiping of the battery stats that syncs the phone and the battery. That's why you wipe the battery stats only after doing the full, complete, three stage charge to a full 100%
  6. #6
    Default
    Quote Originally Posted by Landshark View Post
    ive noticed turning off my wifi has greatly increased my poor battery life with 2.2 (i get great 3g in my area so i dont even need wifi on at home.. its honestly pretty much the same speed loading sites etc)
    ill turn off the gps now also, going to be annoying to activate everytime i use it but i can probably get use to that pretty quickly if itll give me battery life like i had prior to 2.2
    honestly.. i thought battery life was suppose to improve with 2.2
  7. #7
    Default
    Quote Originally Posted by philly View Post
    I personally feel it has improved significantly. Try the thread I linked previously. Gunnermike has put together a great thread on ways to improve battery life, be sure to thank him in his post I'm just the messenger lol
  8. #8
    Default
    Seems identical so far, still getting a little under 4 hours of screen time on a charge.
    GPS/WIFI however seem to be using more juice then they used too.
  9. #9
    Lttlwing16's Avatar
    Posts
    Carrier
    Rooted AOSP
    Default
    juice defender might also be worth considering if your stock..location services is another drainer..
  10. #10
    Default
    For those who arent rooted the battery calibration app will help by deleting the the battery stats and from there you can perform the method above which Sharky stated.
    FearTheGhost13 likes this.
  11. #11
    Default
    Quote Originally Posted by vi3tboiii54 View Post
    Thanks vi3tboiii54! That will be a handy app for rooted folks having battery life issues that want to give gunnermike's thread a try. I for one am having phenominal battery life on stock ED01 so I know it works.. but as always people's "mileage" will vary.
    I'd like to also express that using a live wallpaper will significantly reduce battery faster, and as stated time and time again disable gps and wifi while not in use. It is also said that turning auto rotation off when not needed can help increase battery life as well.
    When charging the battery to 100% don't fully trust that it is 100% full due to the pop up saying it's fully charged... get specific and go into settings>about phone>status and look at the battery level % to be completely sure it is fully charged. (will be 100%) Mine tends to stop at 98-99% sometimes, in which case I unplug and plug back in until it reaches 100%.
  12. #12
    Default
    My battery is getting ripped apart by my display(it used 10% of my battery life when it was on standby?!). I had it set at 24% brightness on 2.1. Now I have it set at 12% and it's still draining like mad.
    Would you mind pointing out which app works for those of us who are unrooted? I searched the market, but to no avail.
  13. #13
    curley's Avatar
    Posts
    Carrier
    AOKP Devil 40.1
    Default
    Turn off the data Roaming also. This helps me considerably. When service is weak, the phone tries to Roam data and sucks battery dry. I am running ED01 Debloated with SD
  14. #14
    Default
    Quote Originally Posted by Big Z View Post
    The battery calibration app is for UNROOTED users
    Edit: Disregard the statement about that app being for unrooted users as I was mistaken, you must be ROOTED in order to use. As of right now I am unsure of an application that can wipe your battery stats without being rooted. I will keep an eye out tho.
    vi3tboiii54 likes this.
  15. #15
    Landshark's Avatar
    Posts
    Carrier
    Default
    Just to further clarify for everyone. Whether you use the app vi3tboiii54 is referencing, or you do it through terminal emulator or adb, you should only wipe battery stats at the point where the battery is at a full, complete 100%, because when you wipe batt stats you are syncing up what your phone is showing as the % and what the battery is actually reporting as the %. You are letting the phone "know" in a sense that this point here is 100% charged.
  16. #16
    Default
    Thanks Landshark, one day I'll be able to clarify things as well as you do lol
  17. #17
    Landshark's Avatar
    Posts
    Carrier
    Default
    Hopefully not, because that would mean you have caught my OCD
  18. #18
    Default
    Haha, trust me I caught it already. I love learning everything I have accessible to me within these forums and I'm very fond of paying it forward and helping people out whenever I can!
    On a side note: The Battery Calibration app is actually for ROOTED users as I was led to believe it wasn't. Just downloaded and installed from market and you must have rooted your phone in order to use. So I think a little clean up is in order for this thread.
  19. #19
    Default
    Is it possible that with the juice defender app it could actually be worse for the phone? I used to use it pre 2.2 and when I had the wifi off having a running service not doing anything was actually worse for the battery it seemed.
  20. #20
    Default
    Quote Originally Posted by MistaDee View Post
    It's very possible I would say. With it being an app and all any time it is running it's going to use the battery in some way shape or form. I personally believe the best way to save battery is just by minimizing how many apps/widgets etc you use and to be sure and close apps etc. that you do not need at the time. I cannot give you a very accurate answer in regards to juice defender due to the fact I've never used it myself. But just keep some of what I said in mind, it should help out.
  21. #21
    Default
    Thank for catching that Fear and my bad everyone I was having major insomnia last night as I was typing out my post and somehow i thought so too. It requires 2.1+root but the app has a sound notification option when it hits exactly 100% for those who hate playing the waiting game by looking at the screen. I found this app through XDA heres the link.
  22. #22
    Default
    Hey no problem man! I know what you mean with the insomnia, that's the story of my life! Seems in order to wipe battery stats in any way shape or form the user is going to need to have rooted their phone. I'm finding nothing whatsoever for unrooted users to do this
  23. Thread Author  Thread Author    #23
    OB1J3D1's Avatar
    Posts
    Global Posts
    29 Global Posts
    Default
    Update: I'm back to about normal if not better than normal on 2.1.
    I turned off a bunch of sounds when things are pressed and stuff and disabled wifi when not in use. I left GPS on because I use it alot. Data roaming is on (but I get pretty good service here) in the notification panel the only things have turned off are WiFi and Bluetooth. Which I turn on when I need em.
    I think it was probably wifi. But, something in me feels that it just needed a few days of use and a few charges and it's back to normal. I can't remember all of my setting changes. But, I'm going to at least turn the wifi back on and give it a good days use to see.
  24. #24
    zombiebot's Avatar
    Posts
    Carrier
    AOKP
    Default
    I use my fascinate a lot, and since no smartphone will last 24 hours with heavy use on a single battery, so I went into Verizon and got one of the extra batteries w/ the charging station.
    I usually wait until the thing is around 5-10%, then I do the old switcheroo, and put the old battery on the charger.
    Is this okay for overall battery performance, or am I confusing my phone?
  25. #25
    Default
    Quote Originally Posted by zombiebot View Post
    Same setup I have. I usually switch batteries around 30-40%. I also charge the phone at night along with the extra battery, start everyday with everything charged.
