Can some one tell me how to connect my phone to the computer so I can root. When I connect to the computer, it shows up as F drive but only stays for a few seconds and then turns to G drive and won't let me put the files on. Any ideas?
I can't get anything to go to my phone. It turns from "f" drive (after a few seconds) to "g" drive and won't let me drag the file to "g"
Yes, it says usb connected, at the bottom it says connect usb storage. When I do that, it takes me to another screen with a orange android guy and it says usb storage in use
I put the files on my computer that need to go on the sd card the others are on odin
Do I need to odin the drivers first? What is screen sharing?
Did you get it. I am not sure if I did it right. (pretty new to this stuff)
