i could very well have blackberry blindness but feel like my samsung fascinate runs through the battery in a much shorter time than my blackberry did. is there anything i can do to prolong the life. a point in the right direction would be appreciated. and number two are task killers worth it or just a battery drain and which one? thanks in advance and hitting the ground running with my fascinate and leaving blackberry in the dust since the first of may!
First off, welcome!
Next I just wanted to say that you do not have Blackberry blindness, the battery is shorter. Reading through that thread will help save you some battery life while you are rolling with the stock setup
When you are ready to start flashing new ROMs to your phone, the new Community ROM and the kernel in it will help you with battery life even more...
And as someone else stated, this forum is fantastic for information and TONS of help with whatever you may need. The guru's are great with info and helping out. If you're not sure of anything, ask away. If you think you have messed the phone up, the first piece of advice is don't panic, it can be fixed...
