Results 1 to 7 of 7
    grayfox99's Avatar
    Posts
    ROM
    2.3.4
    Default Flash player not working!
    Just wondering if anyone else is having the same problem? I can't seem to get flash working on my fascinate, all flash sites I visit tell me I need flash ten or higher. I have 2.2 on my phone, and flash 10.3, I even uninstalled the flash updates and re installed, but none of the flash sites I've visited work, anyone have any suggestions for me?
  2. #2
    Default
    go to your browsers settings and enable plug-ins to always. that should do the trick.
    Thanked by 2:
    grayfox99's Avatar
    Posts
    ROM
    2.3.4
    Default
    Holy crap that worked!! Thanks so much!
  4. #4
    Default
    no problem *thumbs up*
  5. #5
    Default
    Helped me too! Thanx!
  6. #6
    Default
    me three! Thanks a bunch...
  7. #7
    Default Re: Flash player not working!
    Quote Originally Posted by iihyunwooii View Post
    thanks..it really helps
    thanks and regards
