Results 1 to 8 of 8
    Default Rooting problem
    i'm following the steps from
    http://forum.androidcentral.com/veri...-how-root.html
    but it seems like it doesn't work.. on the cmd it says
    Successfully exploited, installing permanent root files and deleting temp files
    Mount: operation not permitted
    /data/local/tmp/com.sh: cannot create /system/xbin/su: read-only file system
    /data/local/tmp/com.sh: cannot create /system/xbin/busybox: read-only file system
    /data/local/tmp/com.sh: cannot create /system/app/Superuser.apk: read-only file system
    Unable to chmod /system/xbin/su: no such file or directory
    Unable to chmod /system/xbin/busybox: no such file or directory
    can anyone help me? i'm really new at this not not familiar with computer/phone stuff so i'm in desperate help.
  2. #2
    Default
    Quote Originally Posted by shydow View Post
    Hey, I recommend trying out POST #5 in this thread: http://forum.androidcentral.com/veri...ing-forum.html
    It's pretty easy and the steps are layed out well, just read through it follow it correctly and you'll be rooted in no time. Hope this helps, enjoy!
  3. #3
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Carrier
    Stock for now
    Default
    If you would like i can root the phone for you over screen share.
    And for future reference please do not follow directions of threads that are closed, they are usually closed for a reason. Most of the time they are out of date
    Default
    thank you both, i'll try it again with the new link.
    and if it still doesn't work can i ask for your help, droidxcon?
    and what is screen share?
  5. #5
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Carrier
    Stock for now
    Default
    Yes ....where I control your computer remotely
    Sent from my SCH-I510 using Tapatalk
  6. #6
    Default
    [IMG][/IMG]
  7. #7
    Default
    Look up super one click on XDA, it roots your phone in 20 secs. Just don't forget to enable usb debugging before starting.
  8. #8
    Default Re: Rooting problem
    Hi I'm trying to root my Evo 3d but it keep saying this
    CAN YOU HELP ME PLEASEEEEEEEEEEEEE!!!...????
