Results 1 to 20 of 20
    Default transfer photos from camera to sd card without using a pc?
    Is there a way to transfer photos from camera to sd card without using a pc?
  2. #2
    atomD21's Avatar
    Posts
    ROM
    Jelly Belly
    Default
    The photos are stored on the SD card by default. Or am I not understanding...
    Android: If it ain't broke, you haven't flashed nearly enough stuff yet...
  3. #3
    Default
    Quote Originally Posted by tn.guy View Post
    You can move the photos by going to My Files > DCIM > Camera > Press "Menu", "More", then "Move".....u should have it from there
  4. #4
    Sta11i0n's Avatar
    Posts
    Global Posts
    961 Global Posts
    ROM
    CM10/Devil
    Default
    The DCIM folder the camera saves to is already I'm the SD card. I'm confused too...
    Sent from my SCH-I500 using Tapatalk
  5. #5
    Landshark's Avatar
    Posts
    Global Posts
    4,417 Global Posts
    ROM
    Infinity & Pool Party
    Default
    I'm confused to. Are you referring to transferring pics from an actual camera to the sd card on your phone?
    Shouldn't we treat this world like the Garden of Eden and avoid the apple at all costs?
    Sometimes you go to the circus...........Sometimes the circus comes to you.
    Instructions on how to flash ROMs, Kernels, Patches, and Mods through clockworkmod recovery, CWM: DroidXcon's CWM Thread
    If you add me on Google+, please list your AC username as a nickname so I know who you are.
    Default
    So why is it when checking out photos in gallery it shows photos on camera, then sd card. I've also noticed that when i had to restore phone, only photo's left, was the ones on sd card and not the ones taken by camera.
  7. #7
    Kevin Gossett's Avatar
    Retired Moderator
    Posts
    Global Posts
    1,688 Global Posts
    ROM
    GummyCharge 1.9.1
    Default
    It's possible you have more than one photo folder on your SD card. That would explain the gallery showing both. But as far as resetting your phone making pictures disappear, that shouldn't happen, because doing a data wipe doesn't touch the SD card (where your pictures are stored)
    Telling a member to "search" is not the answer to a question.
  8. #8
    Default Re: transfer photos from camera to sd card without using a pc?
    I have exactly the same problem: when checking out photos in gallery it shows photos on camera, then photos on the SD card. For some reason my camera is NOT saving the pictures to the SD card. Before I restore factory settings, I want to save all the photos to the SD card. I don't know how to do this. Or I could save them to my PC. But I cannot figure out that either.
    I cannot follow the "go to My Files > DCIM > Camera > Press "Menu", "More", then "Move"..." instruction because I do not know where to find My Files. Don't see it on the settings menu or any of the camera setting options. Thanks for any assistance.
  9. #9
    i love storms's Avatar
    Posts
    ROM
    AOKP Build 33
    Default
    You have to go into the app drawer and find the app, "my files" I think that's what it is called. From there you can follow the instructions given. Hope this helps you out.
  10. #10
    After "Move," then where? I don't see anything that says SD card. Thanks for your help!
  11. #11
    Posts
    ROM
    AOKP Build 33
    Default
    If you are in the"my files" app and are trying to move files, then the files you are moving should already be on the sd card. You would just be moving them around your sd card. Did that make sense? if this isn't you're case people will need more info to help you out, your post is somewhat vague. Hope this helps.
  12. #12
    Default
    Quote Originally Posted by syndega1 View Post
    I have a samsung infues is there a way to move my fotos from my phone to my sd card without a pc
  13. #13
    I think I can clear up some confusion: on my Epic 4G touch, there are 2 types of sd card. There's the regular external sd, which is probably what the poster is trying to get pictures onto and then there's what Samsung is using as the default sd memory, which is really just internal phone memory that happens to be labeled as sd.
    So if you're trying to move your pictures from that internal sd memory to your external sd card, follow the same procedure: My files>tap and hold DCIM>select move> select the folder called external_sd>All done!
  14. #14
    Ok so here's the problem... My Incredible couldnt charge anymore so I got sent an Incredible 2 but my picture didnt get put on the sd card and it was in the phone when I took them and it told me they would be stored there so when I looked on my new phone there were no pictures now I can find someone with a incredible battery thats charged so i can turn the phone on but since the phone cant charge it cant sync to a computer either:l it really makes no sense whatsoever that my old pantech can move files on the phone but i gotta beat around the bush for a "smart phone"
  15. #15
    I have a Samsung captivate and am trying to save pics fro. My gallery on my sd card. I tried what u said to go to files click dcim and hit move but it says operation not permitted in this folder. Pls help
  16. #16
    Thank you this was very helpful!
  17. #17
    Where do I find, My File..... I have looked everywhere but cannot find any file that is listed as "My File"
  18. #18
    Well I have a Nikon Coolpix S205 and I did it by going to my images I pressed the menu button then I clicked copy, when that menu came up I selected from camera to sd card. So it's: Images>Menu>Copy>Camera to SD Card
  19. #19
    The instructions are clear up until I'm told to click on "menu". Just where is that located?
  20. #20
    Quote Originally Posted by phoenixfreefall View Post
    In getting to the DCIM, there's a choice of brow....otos and camera. Nowhere do I see "move"; otherwise, your directions are very clear.
